DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hanging 40Kg on plasterboard
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
macarts
from United Kingdom
PostPosted: Mon Oct 01, 2007 3:40 pm Reply with quote
I am weighing up the options for fixing a 37inch plasma tv on my bedroom wall.
Is it possible to hang a plasma, weighing around 40Kg including the slimline static bracket, directly onto the plasterboard using 6x Spring Toggle Anchors? The beams are in an inconvenient position otherwise i would have used these instead.
The wall is a cavity wall with no brick work to screw raw plugs into.
Thanks in advance
Back to top
 Alert Moderators
peterpumpkin
from United Kingdom
PostPosted: Mon Oct 01, 2007 5:09 pm Reply with quote
Hi, I would fix a plywood board to the wall, fixed to to the stud work, which are probably 3x2 , locating them might be a problem, but you seem to know where they are,they should only be about 18 inches apart at most, in which case you should get al least 3 anchor points.
it might not look too good, but at least it won't fall off!
Back to top
 Alert Moderators
macarts
from United Kingdom
PostPosted: Mon Oct 01, 2007 5:46 pm Reply with quote
Thanks for the prompt response!
Back to top
 Alert Moderators
peterpumpkin
from United Kingdom
PostPosted: Mon Oct 01, 2007 7:27 pm Reply with quote
just rememberd the board we used to use years ago was called Blockboard, this was a sandwich of wood and plywood, with the grain going in different directions to give strength. Nowadays mdf seem to be what is mostly supplied, cant say I have used that much.
pp
Back to top
 Alert Moderators
simoniris
from United Kingdom
PostPosted: Tue Oct 02, 2007 9:57 am Reply with quote
You could cut a section out and replace the plasterboard with BG Glasroc Rigidur H.
This board can take something ridiculous like 30kg off a single fixing....
You would re-finish it just like ordinary plasterboard to get your seamless wall, unlike ply which will always look like painted ply.
It eliminates the need for ply patrisses etc for hanging kit off walls, plasma screen be no problem for it.
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1059 times
PostPosted: Wed Oct 03, 2007 10:38 am Reply with quote
If you are going to those lengths though, you cut cut out the plasterboard, install noggins between the joists, re plaserboard and plaster then just fix through the plasterboard to the noggins.
You could always fit two horizontal lengths of unistrut to the two nearest joists and hang the TV off the 'strut icon_biggrin.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
how to hang 40kg .... on plasterboard!!! 15 7960 Tue Nov 18, 2003 1:13 pm
Mounting a 40kg Multi-Monitor Bracket to a Brick Wall 3 460 Sat Oct 09, 2010 4:23 pm
Hanging pictures and cracked plasterboard 3 560 Sun Jun 23, 2013 10:46 am
Hanging picture on plasterboard 5 4460 Fri Nov 30, 2012 3:55 pm
Hanging heavy mirror on plasterboard 2 1580 Sun Jul 05, 2009 11:19 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
