DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Vynil Tiles
This topic originated from the How to page called Vinyl tiles
Click here to return to the page called Vinyl tiles.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
Jadeboy
from South Africa
Thanked: 0 times
PostPosted: Tue Oct 02, 2007 7:14 am    Post Subject:
Vynil Tiles
Reply with quote Thanks
I have a suspended wooden bathroom and bedroom floor. I want to furnish the bathroom with vinyl tiles. Do I need to waterproof the wooden floor and do one get a vinyl tile thicker than 2mm. I do not want to use ceramic as this will crack between the joist with movement or weight.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Richard C
from United Kingdom
Thanked: 51 times
PostPosted: Tue Oct 02, 2007 7:34 am    Post Subject:
Ceramic tiles can be laid onto a suspended floor with the right preparation & using good quality products but if you really want vinyl, I would consider a good quality floor covering rather than tiles. It will look much better & there is no possibility of water getting between the tile joints into the floor underneath.
__________________
Richard C
Back to top
 Alert Moderators
Jadeboy
from South Africa
Thanked: 0 times
PostPosted: Tue Oct 02, 2007 9:10 am    Post Subject:
Thanks Richard. I would like to cover with ceramics, but thought that vynil would be better considering movement and breakages. I do not want to incur more cost in the long run. I am prepared to spend now on a medium which will last and has a good finish. I came across some advice under the topic "Tiling onto wood". Will definately look onto this.
Cheers
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 51 times
PostPosted: Tue Oct 02, 2007 12:16 pm    Post Subject:
I tiled the floor of a large upstairs bathroom a year ago & no sign of any problems so far. Older properties, like mine, tend to have oversized joists so the suspended floors rarely flex much but if the floor flexes when you walk on it, it will require additional support. I removed the original floorboards to prevent a large step up at the door & laid 22mm exterior grade (waterproof) ply, screwed to the joists every 200mm. Lay the ply so that joins are supported down the centre of a joist one way & support edges in the other direction with stout noggins between the joists if there is any chance of flexing during use; I didn’t bother under the bath or around the extreme edge of the wall. When tiling, use only good quality trade products, the DIY stuff isn’t really up to it. I used BAL flexible tile cement & flexible wide joint grout, its expensive stuff but really the only way to ensure it won’t all crack up.
__________________
Richard C
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Vynil flooring in the kitchen 4 1360 Tue Jan 31, 2006 2:58 pm
Laying Floor Tiles in a Brickwork Pattern 5 1180 Mon Jan 15, 2007 12:03 pm
self adhesive floor tiles 4 480 Sun Jan 14, 2007 1:50 pm
Carpet/tiles query ?? 2 380 Sun Jan 07, 2007 5:03 pm
What tiles are these and how to make them look good again? 4 540 Sat Jan 27, 2007 5:29 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
