Joined: 26 Nov 2003 Posts: 750 Location: Dorset, United Kingdom Thanked: 0 times
Posted: Mon Jun 14, 2004 12:20 pm Post Subject:
Apparently you can use glycerin to remove it but I've never tried this method. I've normally used the totally unapproved way of using persil liquid and loads of water which seems to get most stains off. You're not meant to soak carpet etc, etc but if you've got a stain you've either got to get rid of it or live with it!!
__________________ Never assume tomorrow will get better
Joined: 14 Jun 2004 Posts: 5 Location: United Kingdom Thanked: 0 times
Posted: Sat Jun 19, 2004 5:39 pm Post Subject:
Dont ask me as i still have a coffee stain!!!!! However in my quest for the answer, i have heard that Soda Water and Bicarbonate of Soda work wonders. Also white vinegar! Could try them????
Posted: Mon Jun 21, 2004 8:09 am Post Subject:
Oh well, glycerin's off the list then . You could try a professional carpet cleaning company (although you've probably thought of that one already). I suppose the problem is now that the stain is well and truly dried and set.
Joined: 19 Jun 2004 Posts: 4 Location: United Kingdom Thanked: 0 times
Posted: Tue Jun 22, 2004 11:40 am Post Subject:
Re: Coffee stain 2
hi there, I don,t know whether you,ve got an old piece of carpet that you could try this on. I was advised by 2 carpet fitters to put WD40 on any stain and that would remove it.
Needless to say that I thought they had just been let out for the weekend and no way would I try it.
I didn,t have an old piece of carpet anyway to try it on.
As I say if you are going to try it (but I haven,t) Use an old piece first.
Good luck
Muppett wrote:
Please can someone out there provide me with a fool proof, guaranteed way to remove a dried black coffee stain from a beige carpet????
Posted: Tue Jun 22, 2004 12:11 pm Post Subject:
Funny you should say that. I managed to lift a black mark off some material the other week with WD 40 but then had to use detergent to remove the WD 40!
Posted: Fri Jun 25, 2004 4:35 pm Post Subject:
hi there,
since posting a reply I told a friend of mine about your problem and he said there are loads of tips about stains on the web.
type stains in GOOGLE and hopefully you might find help there.
good luck
Joined: 19 Jul 2004 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Mon Jul 19, 2004 11:26 am Post Subject:
Re: Coffee stain 2
I no how 2 get rit of it gust use this step bye step ting 1.Mix one teaspoon of a mild ph balanced detergent (a mild non alkaline non bleaching detergent) with a cup of lukewarm water
2.Blot
3.Mix one third cup of white household vinegar with two thirds cup of water
4.Blot
5.Sponge with clean water
6.Blot
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
