Joined: 02 Oct 2007 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Tue Oct 02, 2007 9:20 pm Post Subject:
Loft insulation under existing boards
I need to insulate the loft, up to modern standards, but the middle third of the loft is boarded and partitioned to make a junk/games room. I\\\'m getting the two outer areas insulated but none of the contractors I got quotes from have really offered any solution as to what to do with the boarded area. It\\\'s not practical for me to remove the boards/walls, so I would like any suggestions as to what to do with this area.
What options are there? Is it worth looking at loose fill materials? If so, how to install it? Or what about blown fibre - ? How does this work?
Any suggestions from anyone that has had this type of thing done or does it, would be helpful.
Posted: Wed Oct 03, 2007 11:38 am Post Subject:
It's a very big room, so it is not practical for me to remove the walls/boards.
There is only a small amount of insulation between the joists, about an inch or so, in patches.
From inside the un-boarded area of the attic, you can see through gap between the boards and the ceiling below. Hence my original question regarding filling this space without removing the boards.
Joined: 29 Oct 2007 Posts: 1 Location: Cheshire, United Kingdom Thanked: 0 times
Posted: Mon Oct 29, 2007 5:45 pm Post Subject:
Attic floor insulation
I have the same problem as Ian. I live in a 1920s house with a boarded attic. There is blown insulation in the outer area but it has proper floorboards which I do not wish to disturb. I had thought of putting battens with insulation between and then using flooring sheets. Is this feasible. Also someone has plastered between the roof supports and it is grotty. Can I put insulation rolls [the metallic sort] over this or is it a 'chip off job? [sorry about the terminology fellas but I'm new to this and I am starting a bit late in life!]
Joined: 08 May 2009 Posts: 5 Location: Edinburgh, United Kingdom Thanked: 0 times
Posted: Wed Jun 10, 2009 12:50 pm Post Subject:
Existing flooring and glass panel
I'm in a similar situation to the gentleman who started this strand, except that, as well as having a substantial portion of the middle part of the loft planked over, there is a large sliding glass panel that provides access to the loft and light to the large hall via a window in the roof of my bungalow. Are there any cunning ways to improve the insulation of the loft in this situation? At the moment what insulation there is comes from three to four inches of loose fibreglass wool beween the joists while I've stretched a layer of film across the frame of the glassed panel.
Best Wishes,
Peter
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
