DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fitting cat flap to upvc back door
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
Jaffakake
from United Kingdom
Thanked: 1 time
PostPosted: Wed Oct 03, 2007 10:46 am Reply with quote
What is the internal construction of a upvc back door with some moulding on it? Can I just cut though it with a jigsaw and sculpt the moulding so that the cat flap frame will fit? Am I better trying to go through the wall instead?
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1273 times
PostPosted: Wed Oct 03, 2007 5:13 pm Reply with quote
if you have a moulded panel fitted to the door, then a cat flap may not be suitable as the profile will make fitting awkward.
there is no reason why you can't have a plain flat replacement fitted. a cat flap could be installed into the panel before the panel is finally fixed into the door.
Back to top
 Alert Moderators
Jaffakake
from United Kingdom
Thanked: 1 time
PostPosted: Sun Oct 07, 2007 6:52 pm Reply with quote
The whole central panel of the door is one, so to change it makes buying a new door better. I'm sure I could scuplt the edges of the panelling to fit a flap, but wasn't sure what the internal constructions was.
Is it just UPVC?
Would a jigsaw do it?
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1273 times
PostPosted: Sun Oct 07, 2007 9:34 pm Reply with quote
the construction is a laminate of plastic, plywood and foam or polystyrene insulation.
a jigsaw will pi$$ through it.
Back to top
 Alert Moderators
timbalcombe
from United Kingdom
Thanked: 1 time
PostPosted: Sun Oct 07, 2007 10:57 pm Reply with quote
Sorry to Hijack this post;
I already have a flap installed but wish to put another one in.
Unfortunately the new one is longer. I can probably cut the extra length with the panel in situ, but how will I cut accross to complete the opening?
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Mon Oct 08, 2007 7:45 am Reply with quote
You'll need to fit a tunnel to the cat flap, and have the openings standing proud of the door (past the profile). This should result in a fairly neat solution. Best bet is to replace the panel though with a flat one - or get rid of the cat.
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 2 times
PostPosted: Fri Oct 12, 2007 7:42 am Reply with quote
Err not always, mine is plastic Steel plate, foam, plastic. Hard to cut through.
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Fri Oct 12, 2007 9:25 am Reply with quote
timbalcombe wrote:
yeah really handy post knob jockey - sorry- "handyhands"
I wasn't responding to your "hijack" posting, it was to the OP's question icon_rolleyes.gif
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Fri Oct 12, 2007 9:28 am Reply with quote
If the jigsaw has a HSS blade fitted, it should go through all the layers - just make sure the panel is braced so it doesn't "flap" whilst cutting. Also protect the panel whilst cutting, or it'll mark very easily.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Fri Oct 12, 2007 1:33 pm Reply with quote
Well I think so as the cat flap can spoiled the appearance of the door and the wall cat tunnel can be hidden out of sight, behind sofa or curtain
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Fri Oct 12, 2007 4:34 pm Reply with quote
I popped in to see a customer this afternoon, who I installed a cat-flap for last week - exact scenario as above, but I replaced the panel for her.
The cat wouldn't use the flap though, that is until yesterday when next doors dog spooked it and caused it to "fly" through the flap. No problems since !.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Fitting a cat flap in a moulded upvc door 15 20480 Mon Jun 23, 2008 3:01 pm
Fitting a cat flap 14 1500 Thu Jul 15, 2004 8:11 am
cat flap in upvc door panel 3 1100 Sun Feb 03, 2008 6:39 pm
Cat Flap Through Fully Glazed UPVC Door 12 200 Thu Sep 13, 2012 12:00 am
Cat flap in metal upvc door 5 100 Sat Jul 19, 2014 10:48 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
