Joined: 03 Oct 2007 Posts: 4 Location: Buckinghamshire, United Kingdom Thanked: 0 times
Posted: Wed Oct 03, 2007 3:49 pm Post Subject:
OUTSIDE DRAIN
I am relocation my washing machine to a wall which is too far to plumb/drain to. basically there is nowhere for the waste water from the w/m to go to. I have been told that the option is to install a new drain outside. anyone know what this involves and how much it\\\'d cost and do I need planning permission to get a new drain put in .. someone please advise ... i\\\'m getting really stressed out with building dilemmas and we haven\\\'t even started anything yet !!!!
Posted: Wed Oct 03, 2007 4:10 pm Post Subject:
OMG
I am amazed at the speed of your responses .. wow and thanks !!!
anyway ... yes the sensible option would be to put the w/m somewhere else .. however it has been relocated as I have had a kitchen designed (and am paying big bucks for it). anyway kitchen design is based on new french doors in kitchen and thus only place for w/m was on that wall. so my only options are to redesogn kitchen, which means i can't have my french doors (eventually into future conservatory) where i want them or to get drain put in outside near that wall.
apparently the plumbing would have to go across the french doors or outside and is too far to go round back of the house and then around the side where the other drainpipes end up.
what sort of work is involved and how much am i looking at ......
Posted: Thu Oct 04, 2007 11:21 am Post Subject:
the point is that I want this particluar design .. the w/m couldn't be placed anywhere else due to a wider opening (to be done yet) being installed .. so lost a bit of wall space for units/appliances .. not the designers fault ....
anyway ... i think getting a drain is the only option .. if it was just about installing a w/m then i wouldn't do it but it's about a whole new kitchen and a new opening for french doors which will eventually lead into a conservatory (to be arranged)
don't see how drawing would help as would have to pinpoint where pipes are currently and as i said before it means going across a door opening of about 1500 - 1600mm.
£500 when you're spending £20k in context isn't much
so will expect quotes of around £500 for this work .. was that purely labour or plus matls ?
Joined: 06 Sep 2007 Posts: 737 Location: Lancashire, United Kingdom Thanked: 0 times
Posted: Thu Oct 04, 2007 11:43 am Post Subject:
Its really tricky to budget a accurate price based on a conversation.... Ya never know some smarty pants might come up with a £50 fix
This I can tell you ....... Digging is hard work...... I've never met anyone that actually likes doing it ...... Thus its expensive ....... So I'd do that bit myself, its now just a case of knowing what to dig & where ...... Probably & by how much..... & if at all possible use a bobcat
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
