DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fuse box master switch
This topic originated from the How to page called Installing a electrical mounting box
Click here to return to the page called Installing a electrical mounting box.
  View previous topic :: View next topic
Author Message
eck1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jun 15, 2004 11:37 am    Post Subject:
Reply with quote Thanks
I was about to remove some sockets the other day and instead of having to work out which fuse was the correct one to remove, I just switched off the master switch - nothing happened! All the lights stayed on. I can remove individual fuses but it strikes me as a bit odd (and possibly dangerous). Any ideas on what is wrong or how to fix it. It's a fairly old-looking fuse-box (don't know how old as I've just moved in).
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
dingbat
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jun 15, 2004 12:03 pm    Post Subject:
Are you sure there is only one main switch? You don't think you may have turned off the main switch on an old economy seven fusebox, do you? (It will be coloured white and is probably full off blue, 15A fuses).)
You should have a service head, which contains the main fuse, then the meter/s and then any isolators/consumer units/fuseboxes. If you are sure there is only one main switch, but it doesn't isolate the circuits in the house whereas pulling the fuses does, then your main switch is b*ggered and you're in for some expense.
Or maybe what you think is a main isolator is in fact for a single circuit, perhaps for a cooker or shower?
Call in a spark and get a professional opinion.
Back to top
 Alert Moderators
eck1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jun 15, 2004 12:50 pm    Post Subject:
thanks.
I'll have a look again tonight to double check I'm not just being dim!
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Tue Jun 15, 2004 3:56 pm    Post Subject:
so pulling fuses in the same fusebox as the nonfunctional main switch cut off some stuff?
can you get us a complete photo of your fuseboard area?
Back to top
 Alert Moderators
eck1
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 16, 2004 8:27 am    Post Subject:
Sorry, I was being dim. I looked a bit harder and found the master switch, which works ok!
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Wed Jun 16, 2004 9:02 am    Post Subject:
Now I'm curious. The first switch you found, which you originally thought was the master switch - what was it?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Wed Jun 16, 2004 8:38 pm    Post Subject:
HEY!
WHO TURNED MY &%&**^%( PC OFF????
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Wed Jun 16, 2004 8:47 pm    Post Subject:
id guess a plug in mcb. possiblly supplying a disused cuircuit
Back to top
 Alert Moderators
eck1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jun 22, 2004 11:48 am    Post Subject:
Haven't looked again to find out what the first switch was. I'll try to have a look again tonight if I have time after removing radiators!
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Removing Master of a Two Way Switch 10 540 Sat Apr 12, 2008 2:21 pm
Multiple consumer units and master switch 6 1200 Thu Aug 25, 2005 10:05 am
Master phone socket not working 6 540 Mon Sep 26, 2005 8:34 pm
Varilight - Master/Slave two way circuit wiring problem 7 500 Tue Dec 06, 2005 12:15 pm
Moving a phone master socket and swap for nte5 11 4460 Thu Jun 15, 2006 2:36 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
