DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
render onto metal lath
This topic originated from the How to page called Rendering
Click here to return to the page called Rendering.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
  View previous topic :: View next topic
Author Message
eastb
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 04, 2007 8:40 pm    Post Subject:
Reply with quote Thanks
rendering onto timber frame using celotex between building paper and riblath 1. do i need lime in the mix 2.can i get away with two coats
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
noseall
from United Kingdom
Thanked: 71 times
PostPosted: Sat Oct 06, 2007 8:30 am    Post Subject:
lime in the top coat only.
waterproofer in both coats (high suction-warm weather).
waterproofer in top coat only (low suction-cool weather).
we use two layers of metal lathe, as it helps the render to bond better and not push through as bad.
Back to top
 Alert Moderators
eastb
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 12, 2007 6:49 pm    Post Subject:
thanks the reason we use building paper is to stop it pushing through. the s/steel lath (red rib) was advised by expamet rather than mesh to get more render next to the timbers and of course s/steel screws for fixings. my main concern is whether two coats to be ok.thanks for your advice but two layers of lath would have been expensive
Back to top
 Alert Moderators
Micilin
from United Kingdom
Thanked: 6 times
PostPosted: Sat Oct 13, 2007 6:46 pm    Post Subject:
Usually we go
One p***k coat, one scratch coat , one float coat.
It all depends how good you can get your first coat, as your float coat should ideall be of uniform thickness and not too heavy.
You can often be quicker and leave a better job with three coats onto wire than with three, but it depends how well the mesh is fixed. It is often easier to bead onto a p***k coat too.
Obviously the coats get weaker as you come out
Back to top
 Alert Moderators
eastb
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 15, 2007 5:16 pm    Post Subject:
Thanks all
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
metal stud walls 3 180 Wed Jul 22, 2009 7:23 pm
Dry lining - Speedline metal system, setting out query 2 180 Wed Sep 02, 2009 8:16 am
Lath and Plaster Replacing with drywalll 4 520 Sun Jul 13, 2008 8:57 am
cracks in plaster and lath ceiling 2 600 Mon Jun 23, 2008 4:05 pm
Skim Lath and plaster ceiling 2 800 Wed Feb 27, 2008 12:02 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
