DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Heatline C28 Pressure Problem
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
AChantry
from United Kingdom
PostPosted: Fri Oct 05, 2007 11:32 am Reply with quote
I have recently moved into a property that has a Heatline C28 Combi boiler installed. The previous owners have been kind enough to take the instruction manual with them (or bin it at least) and I am unsure of how to sort out a pressure problem that I am experiencing.
After moving in I noticed that the upper-most radiator was not heating up so I bled it. After this the pressure has dropped to below 1 bar. I understand that it needs to be re-pressurized via the temporary filling loop, the only problem is that I have absolutely no idea where this may be located.
Can someone please help?
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3534 times
PostPosted: Fri Oct 05, 2007 12:16 pm Reply with quote
See FAQ.
Its not part of the boiler and will be on the pipework somewhere, either under the boiler or behind the washing machine machine.
Unfortunately muppet installers think that putting it behind the washing machine is a suitable place.
Last week I came across one under the cooker. It was turned on after I left and the owner did not who why! The Staffi and I knew though!
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Heatline Vizo 24 air pressure switch problem 4 80 Wed Jan 29, 2014 12:13 am
High ....then Low pressure with Heatline compact 6 1280 Thu Oct 30, 2008 9:02 am
diagnose my over pressure in heatline combi 11 860 Thu Apr 17, 2008 6:36 pm
Help! Heatline S30 pressure too high 5 680 Thu Nov 19, 2009 8:12 pm
Where is the pressure valve on my Heatline Compact Boiler?! 5 1360 Fri Oct 10, 2008 3:06 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
