DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Leaking swivel mixer tap
This topic originated from the How to page called Repairing a leaking tap
Click here to return to the page called Repairing a leaking tap.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
tobymac
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 06, 2007 7:31 am    Post Subject:
Reply with quote Thanks
I have a swivel mixer tap in my kitchen which is leaking at the base of the swivel bit, can anyone help me on how repair it please?
Many thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
TicklyT
from United Kingdom
Thanked: 20 times
PostPosted: Sat Oct 06, 2007 8:30 am    Post Subject:
Most swivel spouts are sealed by 'O' rings fitted on the spigot at the bottom of the spout.
Some spouts are held in place with a small screw fitted in the back of the tap. Remove the screw and the spout should pull out.
On others, the fixing is not unlike a bayonet light bulb fitting. Turn the spout to one side (usually beyond the usual range of movement), and there is a position where the spout can then be pulled out.
Some monoblocs require removal and dismantling of the complete tap assembly to release the spout.
__________________
If it isn't broken, keep fixing it until it is
Back to top
 Alert Moderators
tobymac
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 06, 2007 12:11 pm    Post Subject:
TicklyT
Many thanks for your help.
Had to go to 4 different DIY stores to finally get the O rings that I needed but it's all fixed now.
Cheers.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Monobloc Mixer tap spout is stiff to swivel 2 1720 Sat Oct 14, 2006 1:48 pm
Kitchen swivel mixer 7 1120 Fri May 27, 2005 11:41 am
Leaking Kitchen Swivel Tap 4 980 Fri Aug 26, 2005 7:13 pm
Stiff swivel tap 4 800 Mon Aug 16, 2004 3:21 pm
monobloc swivel spout leak 9 6940 Sun Feb 27, 2005 5:28 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
