Turn the heating on for the first time to find that its running noisily.
There is a pipe that vibrates that i can stop by holding it so i obviously need to put a clip on that pipe, but there also seems to be a thruming noise coming from the whole system.
The thrumming noise is loudest in the bathroom where the central heating pump is, but when the boiler and pump is running to just heat the hot water and not the radiators, the noise isn't there.
To get to the pipes under the bathroom floor i'd have to lift a load of stuck down vinyl tiles which i don't want to do unless its absolutely necessary.
Is there anything else i can do or check to reduce the noise? Turning the pump speed down works, but obviously the radiators don't get as hot and the boiler has to be turned down or you can hear water boiling in the heat exchanger.
Thanks in advance.
Thanks in advance.
