frasul
Joined: 08 Oct 2007 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Mon Oct 08, 2007 7:01 pm Post Subject: Boiler not firing on constant heating demand |
Hi
I\\\'ve got a Worcester Combi boiler and the boiler fires up when hot water tap is turned on. However when i flick the button to have the boiler come on with the timer or flick the swith to have it constantly on the boiler does not fire up! Any suggestions. Also i did notice some water dripping from below the boiler. Prior to this i had fitted a washer/mixer tap with a thermostat in it in the upstairs bath. Small adjustments to the thermostat do not change the water temp but large adjustmetns make the water temp change from very cold to scalding hot! Are the 2 problems connected?  |
Agile
Joined: 26 Jun 2004 Posts: 24311 Location: London, United Kingdom Thanked: 193 times
Posted: Mon Oct 08, 2007 8:15 pm Post Subject: |
Worcester have made many different boiler models and some have had limited DHW control.
It sounds as if you dont want to call a professional to deal with a leak in your boiler.
By aware that water and electricity dont mix! Water can cause expensive damage to electronic components in boilers.
Tony |
