Joined: 16 Nov 2005 Posts: 4 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Tue Oct 09, 2007 9:14 pm Post Subject:
Baxi 105HE losing pressure and air in system
Looking for advice on the above boiler..... System continuously needs topping up, maybe every few days but towel rad in bathroom needs bleeding dailty to top up..... Cannot see any visible leaks anywhere.
Joined: 12 May 2004 Posts: 7929 Location: United Kingdom Thanked: 59 times
Posted: Tue Oct 09, 2007 9:23 pm Post Subject:
Do you have any pipework under concrete floors or floorboards downstairs where the water could be leaking too..... or possible leak inside boiler turn off the two black taps under the boiler which are located on 22mm pipe on either side leave the inner one on 15mm alone. if the pressure drops with these of the leak is in the boiler somewhere
Posted: Wed Oct 10, 2007 9:23 am Post Subject:
Thanks for that..... Live in a Terrace house where downstairs is concrete floor so all pipework is above surfece......will give turning valves of a try..... Would this explain why the towel rad constantly needs bleeding????
Joined: 18 Feb 2006 Posts: 557 Location: Turks and Caicos Islands Thanked: 0 times
Posted: Wed Oct 10, 2007 2:53 pm Post Subject:
Secondary heat exchanger ?
If this is split/holed you will loose water through it,not always apparent with the boiler off,and unfortunatly when the boiler is running it can be confused with condensate.
Pressurise system to about 3bar,with boiler off see if any water passes into condensate trap.
Or pressurise boiler to about 3bar and isolate at boiler flow and return,leave for 24 hours,if no drop boiler o.k....
Joined: 28 Oct 2007 Posts: 3 Location: Warwickshire, United Kingdom Thanked: 0 times
Posted: Sun Oct 28, 2007 7:02 pm Post Subject:
Advice required on how to pressurise a Baxi Combi boiler
Please advise how to pressurise the above boiler?
We inherited a baxi combi boiler in a new house, having been used to a Worcester Bosch that came with a filling key previously.
Instruction booklet not helpful as states to call a service engineer. But, you always need this info on a Sunday night!
Not immediately obvious looking at the boiler and not very technically minded I'm afraid.
Posted: Mon Oct 29, 2007 8:40 am Post Subject:
Have a look under boiler is there a silver braided hose with one or two taps on it turn the taps on till presssure goes up to say 1.5 and it should be ok , remember and turn taps off though(don`t touch the 3 at the back of boiler)..
If its not there have a look below boiler and it should be conneccted to the right hand pipe somewhere
Joined: 08 Nov 2009 Posts: 6 Location: Essex, United Kingdom Thanked: 0 times
Posted: Sun Nov 08, 2009 7:03 pm Post Subject:
I have the same problem as in the lead of this thread. At first, the boiler was very noisy and thought it was maybe over heat, but of course, it was noisy due to lack of pressure!
Heat Team been out twice now and haven't fixed issue. I can keep calling, as I have cover. Is there anything I can do to look to solve this, please?
Last engineer suggested fitting a descaler on the cold water feed. I can see how this would help to prevent future problems, but can't see how it would solve continual pressure drop.
Same fault - I have to re-pressurise nearly every day and bleed towel rail. I have no experience, but willing to listen!
Joined: 18 Sep 2008 Posts: 5 Location: Bournemouth, United Kingdom Thanked: 2 times
Posted: Sun Nov 08, 2009 7:41 pm Post Subject:
There are a few faults I can think of either you are topping and airing the system whilst it is hot so you fill on the expansion and then when the system is cold it appears to be under presure, or the fault could be a passing prv or a popped or depleted expansion vessel or as previous could be a exchanger fault hope this helps Jordon
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
