DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Am i about to get ripped off ?
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
The_Daws
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 10, 2007 5:50 pm    Post Subject:
Reply with quote Thanks
We have a Alpha 240 Eco combi boiler. Everything was working fine until i decided to try the central heating before things got to cold. All the radiators heated up (although some a bit hotter than others) and i thought we would be set. However, after switching the central heating off i found later that night that the hot water was starting to play up. Basically, i turn on the hot water, the boiler fires up, makes a howling noise for about 2-3 seconds and hot water comes out of the taps. After a very short time the boiler then shuts down. A little while later the boiler fires up again, before once again turning itself off (repeat for as long as you run the water). The result is a luke warm bowl of water or very miserable shower. The central heating however, remains absolutely fine. I called British Gas who said that the heat exchanger was getting blocked. The engineer recomended fitting a MagnaClean device and changing the heat exchanger, quoting £260. He did make a show of taking the heat exchanger off and showing my wife the black particles (no jokes please) but i am concerned that we might be being had over. A friend had a similar experience with British gas and there eagerness to sell heat exchangers. Any advice on the price quoted and the work proposed would be appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
nickso
from United Kingdom
Thanked: 21 times
PostPosted: Wed Oct 10, 2007 6:32 pm    Post Subject:
£260 doesnt sound too bad for that.
whether or not you need a magnaclean is not for anyone here to confirm as it will solely be dependant on the water quality.
if you dont like the price get a second opinion. you could always refuse the magnaclean and get the h/e on its own but you may end up in the same position fairly soon if you do.
you dont say whether you are on BG contract or if this was an on demand call-out.
Back to top
 Alert Moderators
rob884
from United Kingdom
Thanked: 2 times
PostPosted: Wed Oct 10, 2007 6:35 pm    Post Subject:
Personally id have spent an extra 10 mins to give the HE a quick flush and probably get it temp working again. That way the customer can appreciate it needs to be done.
Although usually i wouldnt bother removing it at all.
They have advised you correctly IMO. Cant really comment on price maybe you could get a couple of rough quotes over the phone?
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 400 times
PostPosted: Wed Oct 10, 2007 6:40 pm    Post Subject:
Re: Am i about to get ripped off ?
doyle
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
The_Daws
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 10, 2007 6:51 pm    Post Subject:
Thanks for the advice. The engineer must have flushed the exchanger through as suggested because the water is now running hot (nice to feel clean again!). The boiler is still a bit noisy so perhaps the work does indeed need doing.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Wed Oct 10, 2007 6:59 pm    Post Subject:
I think it is a very reasonable price as the Magnaclean is around £100 on its own.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
kevplumb
Thanked: 400 times
PostPosted: Wed Oct 10, 2007 7:01 pm    Post Subject:
perhaps you need a size nine up your rear
we are not all bandits
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
The_Daws
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 10, 2007 7:27 pm    Post Subject:
Kevplumb..
What do you expect. Your profession has hardly done itself any good in recent years. The incident i refer to that a colleague experienced, from a British Gas engineer was as follows..
Your heat exchanger needs replacing luv and the boiler flushing. That'l be £500 thankyou.
Engineer returns with replacement part but wants my friend to keep out of the way. My friend decides to stay and watches them produce a part that appears in even worse condition than the one they intend to replace. He seems surprised when my friend objects.
As for my own experience. I have a British Gas contract. I never see the same engineer and have experienced differing levels of competence.
Thanks to those who replied to my genuine question.
Kev, your a plum.
Back to top
 Alert Moderators
lcgs
from United Kingdom
Thanked: 33 times
PostPosted: Wed Oct 10, 2007 7:37 pm    Post Subject:
Bg are currently cahrging £190 just to fit the magnaclean.
Back to top
 Alert Moderators
nickso
from United Kingdom
Thanked: 21 times
PostPosted: Wed Oct 10, 2007 8:24 pm    Post Subject:
i cant see what possible reason the BG engineer had to replace your mates part with a second hand one.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Wed Oct 10, 2007 9:07 pm    Post Subject:
I find it difficult to believe that a BG engineer would be fitting a second hand part during his employement with BG. Much more likely he was working on the side!
As the Magnaclean is about £100 to buy then supply and fit for £190 sounds very good value indeed.
We are considered to be very reasonable in our pricing policy but would normally charge £220 although that would include a visit a few weeks later to clean the filter and advise on any further treatment required.
Tony
Back to top
 Alert Moderators
Nixt
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 10, 2007 11:47 pm    Post Subject:
Quote:
Kevplumb..
So based on these anecdotal titbits you've managed to assess the state of an industry of over 50,000 souls servicing over 17,000,000 properties.
Back to top
 Alert Moderators
mehran
from United Kingdom
Thanked: 6 times
PostPosted: Thu Oct 11, 2007 12:09 am    Post Subject:
tho i have no love for bg, the price for fitting a magnaclean and new heat exchanger is more then fine. at least he did not try and sell a £600 powerflush icon_rolleyes.gif
Back to top
 Alert Moderators
oilman
from United Kingdom
Thanked: 7 times
PostPosted: Thu Oct 11, 2007 6:41 am    Post Subject:
The_Daws wrote:
Kevplumb..
What do you expect. Your profession has hardly done itself any good in recent years. .
Name ANY trade/profession/service where there is no chance of being ripped off.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Thu Oct 11, 2007 6:47 am    Post Subject:
oilman wrote:
The_Daws wrote:
Kevplumb..
good point oil
__________________
If at first you don't succeed, remove all evidence you ever tried.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Ripped Off 78 year old lady 21 1020 Mon Mar 02, 2009 8:17 pm
Ripped off by some parts merchants 15 640 Mon Oct 20, 2008 5:53 pm
Have I been ripped off with my powerflush? :-( 46 1740 Sat Jun 20, 2009 7:55 pm
Ripped off 41 2640 Thu Aug 20, 2009 5:51 pm
Bathroom refit.....Am I being ripped off? 5 280 Sun Sep 27, 2009 9:02 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
