robark
Joined: 10 Oct 2007 Posts: 1 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Wed Oct 10, 2007 6:13 pm Post Subject: Draught Proofing |
I have recently bought an old house which already has foam draught proofing around the internal doors. This has cracked over the years and I need to remove before applying fresh. Could anyone let me know the best way to remove old draught proofing. |
Fleeting Glimpse
Joined: 08 Oct 2007 Posts: 28 Location: United Kingdom Thanked: 1 time
Posted: Wed Oct 10, 2007 6:56 pm Post Subject: |
I suppose you need something to dissolve the adhesive once you have pulled a s much of as you can.
White spirit may help. |
MasterAbacus
Joined: 16 Jun 2005 Posts: 503 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Fri Oct 12, 2007 3:25 pm Post Subject: |
Pull it off, the best you can..... and buy a can of sticky label remover.... Best if found comes in an areosol format.... and it smells of Oranges...
Might be an idea to try a small area first, just incase it strips the paint... |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Fri Oct 12, 2007 3:49 pm Post Subject: |
a lot of adhesives will dissolve either in white spirit, or in meths. both are cheap. |
