Is 1990mm x 804mm a standard door size?
28 Jul 2007
Warwickshire
I need to replace the door between my kitchen and attached garage.
I've measured it as 1990mm x 804mm. It's a good close fit to the door frame. It doesn't appear match any of the standard metric or imperial sizes I've found listed.
Does anyone know if this is a standard size of door?
Also, I believe that a door in this location should be half hour fire rated. The existing door isn’t fire rated but the replacement probably should be.
I assume that a fire rated door can’t be trimmed down to fit due to the inturnescent strips?
Thanks.
I assume that this means that the door isn't a standard size?
So I'm either going to have to trim a door to fit the frame, or modify the frame to fit a standard door.
Any advice would be much appreciated.
