DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
IMMERSION HEATER
This topic originated from the How to page called Immersion heater thermostat control
Click here to return to the page called Immersion heater thermostat control.
  View previous topic :: View next topic
Author Message
jeanieJo
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 13, 2007 10:04 am    Post Subject:
IMMERSION HEATER
Reply with quote Thanks
I have a water heater running overnight on economy 7 tariff. I am going away on holiday in December would it be safe to leave it on so that the pipes dont burst in a cold spell or would it be dangerous with the water overheating with no-one using it?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Diyisfun
from United Kingdom
Thanked: 9 times
PostPosted: Sat Oct 13, 2007 10:13 am    Post Subject:
Why leave it on, whilst it will cycle & will not over heat & it will noithing to stop pipes bursting.
If you are going away for more than 2 days turn the immersion off, before you go so that you use the hot water that is already in the tank, shower/ bath etc.
It shoould only take couple of hours to heat up on your return & you will have saved a few pp's
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Oct 13, 2007 10:14 am    Post Subject:
your theory wil not work, since the immersion heater will only heat the water in the tank.
when we go awy we leave the CH on but very low temp
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
kevnurse
from United Kingdom
Thanked: 3 times
PostPosted: Sat Oct 13, 2007 10:42 am    Post Subject:
All of your water pipes that are not insulated (and are therefore vulnerable to freezing) should be located in areas of your home that are heated. Thats the theory. So, you take the responsibility for protecting those pipes by maintaining those rooms' temperatures above 0 degrees C at all times. When you leave the house during winter you should set the heating in rooms with pipes to a low room temperature (above zero). This should prevent all exposed pipes in your home from freezing.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 16 times
PostPosted: Sat Oct 13, 2007 1:34 pm    Post Subject:
surely even an insulated pipe can freeze if it is cold enough for long enough...
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Wiring a new 24 hour immersion heater timer 6 320 Sun Jan 18, 2009 4:16 pm
Remote switch for immersion heater on ring 21 840 Wed Oct 10, 2007 2:34 pm
Immersion heater wiring 6 420 Tue Oct 30, 2007 12:40 am
Immersion heater drawing 8Amp? 3 340 Mon Sep 10, 2007 8:06 pm
Immersion heater help. 12 460 Tue Feb 03, 2009 6:48 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
