Lesleyprez
Joined: 13 Oct 2007 Posts: 3 Location: Gloucestershire, United Kingdom Thanked: 0 times
Posted: Sat Oct 13, 2007 1:00 pm Post Subject: New blocks are too thick |
After searching for ages I found some pitch pine parquet blocks which matched my existing floor. They are the right length and width but are too deep, which type of saw do I need to cut about 1/4 of an inch off the bottom?
Any advice would be gratefully received! Thanks
Lesleyprez |
big-all
Joined: 12 Jul 2004 Posts: 5771 Location: Surrey, United Kingdom Thanked: 24 times
Posted: Sat Oct 13, 2007 2:55 pm Post Subject: |
heeeelllooo and welcome Lesleyprez
not an easy task
phone your local joinery shop
allow extra thickness for adhesive take all your blocks to them hey presto proper job for for about £1 or less per block [assuming around 20 blocks] __________________ big all
we are------------------ all still learning |
mattysupra
Joined: 30 Jan 2007 Posts: 1650 Location: West Midlands, United Kingdom Thanked: 5 times
Posted: Sat Oct 13, 2007 7:49 pm Post Subject: |
or if you have plenty more than 20 blocks, go and buy yourself a thickener from b&q warehouse |
big-all
Symptoms
Joined: 11 Sep 2007 Posts: 1297 Location: United Kingdom Thanked: 0 times
Posted: Sun Oct 14, 2007 1:05 am Post Subject: |
Lez - 1/4", use a bandsaw - buy a cheap one or follow Big's advice and get the local carpentry workshop to do it. Even you local timber yard might help. |
Deluks
Joined: 23 Feb 2005 Posts: 3612 Location: Surrey, United Kingdom Thanked: 24 times
Posted: Sun Oct 14, 2007 12:21 pm Post Subject: |
Got a router? Start with a flat worksurface, ie: sheet of ply or mdf. Affix to this a piece of 18mm ply with a squared off hole cut in the centre, an inch larger than your blocks all round. Inset into this a piece of 12mm ply, with an inset cut out the same size as your blocks. Then you have a jig which you can use to hold the blocks in place while you router off the excess depth. Sizes given are examples, but you get the gist. |
