DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Dimmer buzzing loudly in middle position
This topic originated from the How to page called Replacing a one-way light switch with a dimmer switch
Click here to return to the page called Replacing a one-way light switch with a dimmer switch.
  View previous topic :: View next topic
Author Message
BrigadierA
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 14, 2007 10:35 am    Post Subject:
Reply with quote Thanks
I've just fitted a brass dimmer to replace an existing light switch on a 100W normal bulb. When the dimmer is in the off or full on position then there is no noise, but the closer I move it to the middle position a buzzing noise appears and gets louder the closer to the middle setting I get.
The last brass dimmer I fitted on a 100W bulb was four years ago and that makes no noise at all and is on the same upstairs circuit.
The differences are the model of dimmer is different (it can be switched on and off by pushing in) and this new dimmer is 2 way (but wired for 1 way).
Do you think this dimmer is faulty?
Anything else I should check?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Oct 14, 2007 10:44 am    Post Subject:
no the dimmer is working fine, some dimmers do that, change brand and have the same as the other one you have
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
BrigadierA
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 14, 2007 11:56 am    Post Subject:
Any recommendations on a non buzzing brass dimmer?
I have a Wickes (where this came from), B&Q, Homebase and Focus Do It All just round the corner from me.
Back to top
 Alert Moderators
Space cat
from United Kingdom
Thanked: 3 times
PostPosted: Sun Oct 14, 2007 12:18 pm    Post Subject:
Sorry but any dimmer has the potential to buzz. It's magnetostriction in the core of the suppressor coil that causes it. This can be reduced by using more core material so that it isn't driven so hard. (But it can also be reduced by using inferior suppression!) All other things being equal, a higher rated dimmer (more watts) will be quieter but watch out because dimmers often have a MINIMUM power rating too!
__________________
Their base is so secret, even the space cats don't know where they are.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
NO UPSTAIRS LIGHTS! Light switch stuck in middle position. 10 480 Fri Dec 26, 2008 7:25 pm
Power socket in middle of a room 18 800 Mon Jul 30, 2007 5:36 pm
Stuck in the middle - 16th to 17th editions - Opinions? 14 620 Sun Feb 24, 2008 10:07 pm
Kitchen downlighter position 5 380 Thu Nov 02, 2006 10:34 pm
Cooker Hood switch Position 9 1720 Mon Nov 20, 2006 6:39 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
