DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Parquet adhesive and finish queries...
This topic originated from the How to page called Wood block / Parquet floors
Click here to return to the page called Wood block / Parquet floors.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
jackhobhouse
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 16, 2007 9:33 pm    Post Subject:
Reply with quote Thanks
I have just bought 36 sq m of Reclaimed Oak parquet - it is not very old however, only a few years. As such there is no Bitumen on the back, just some adhesive and grit which comes off fairly easily although i can't see myself easily getting all the hardened adhesive off. It is a fairly thin layer. I plan to lay herringbone with a 2 block edging strip.
My question is what adhesive should i use to fix this onto the concrete floor of my flat. I'm on the third floor so i assume there will be no problems with damp in the floor. Ideally i want something that will go on thick to accomadate the random bits of adhesive on the wood blocks.
Also Is it true that the best way to do the edge is to lay beyond the line and then use a saw to cut a straight line along the edge, thus eliminating the need to cut all the fiddly bits inbetween? If so what sort of power tool do i need for this?
The blocks are currently a not particularly nice orangey colour but when sanded return to a good pale oak colour. How can i maintain this when applying a finish without too much darkening or returning to the orange colour. Any suggestions on product?
If anyone can answer any of these queries i would be incredibly grateful! Then i can finally tackle the monster pile of blocks in the corner of my living room....
Jack
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Wed Oct 17, 2007 10:04 am    Post Subject:
Hi Jackhobhouse
Any normal parquet adhesive should do, like lecol5500 or B92 (F.Ball Stycobond). Use a notched trowel!
We normally use a plunge saw to cut the straight line in the pattern before installing the border.
Orangy colour - most pine boards end up that way, Oak normally turns honey colour.
If you don't want either we recommend 'golden Oak' hoardwaxoil
hope this helps
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
solid oak queries 4 400 Tue Dec 02, 2008 10:58 am
parquet floor finish - newbie 13 1580 Tue Oct 04, 2005 10:10 am
Granite Tile Finish 3 680 Tue Nov 22, 2005 4:08 pm
Tile finish Problem 2 600 Wed Nov 16, 2005 9:54 pm
Oak floor finish/sealer 2 2880 Thu Jul 28, 2005 11:50 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
