Help created hole in pipe!
tej
12 Dec 2005
Hi
Was taking skiring boards off last night and in the process i made a small hole in the system.
I thought id turned off the central heating valves there are 2 located at the bottom.
I drained the radiator system but the pressure dropped. But when i repressurised it started to leak again as the water must have gone in the pipe
if the valve was closed would the repressurising cause water to go through the pipes.
ps. i looked manual but no joy i wanted to know which way would be close? i did it with a spanner
Stressing now! pressure was 0.1 this morning!
HELP!
Don't really follow :confused: First thing you need to do is fix the hole :eek: Then re-fill the system :rolleyes:
i might not be able to do that till weekend as i might have to get someone
So in the meantime i wanted to stop water going into the central heating system. but keep the hot water running
so as a temp stop to the leak will turning the central heating valves allow me to repreussrise the system for the hot water
hope this is clear
Only if the boiler has a built in filling loop that is boiler side of the ch isolating valves.
its a vokera boiler linea 24
theres a seperate lever for filling the system.
and theres 2 on the left which are for central heating flow
whats a good temporary fix for this?
NO!! Heating system must be filled to make the boiler work!!!
There is no temporary fix!!
Fix the leak and then pressurise your system.
Help is in the PLUMBING TIPS section above. :D
