DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Bathroom Fan heater wiring help
Author Message
emphasis303
from United Kingdom
PostPosted: Wed Oct 17, 2007 7:31 pm Reply with quote
Hi Guys
I have a 2kw Wall Mounted Bathroom Fan Heater by SONEVA that needs wiring, it takes a live and a neutral wire but no earth.
my question is if the other of the cable running into it is a standard uk plug that plugs into the plug socket, is there a need to earth the appliance? if so how do i do this if the heater only takes live and neutral.
The instructions say to fuse it with 13amps
thanks alot
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 342 times
PostPosted: Wed Oct 17, 2007 7:37 pm Reply with quote
You cannot plug this appliance in using a plug and socket arrangement if it in a bathroom containing a bath or shower!
Back to top
 Alert Moderators
emphasis303
from United Kingdom
PostPosted: Wed Oct 17, 2007 8:23 pm Reply with quote
Hi
Thanks for letting me know, but incase I didnt make it clear the socket for the plug would be outside of the bathroom in the room next door would that be ok? if not I have an old extractor fan that stopped working a few years back but never changed it, could I use the wires that used to work for it on the fan heater? Im guessing i just connect the live and neutral and it should work right? and once again no earthing right?
Thanks again
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 308 times
PostPosted: Wed Oct 17, 2007 8:26 pm Reply with quote
The extractor is possibly from the lighting circuit which cannot accept a load such as a heater.
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 570 times
PostPosted: Wed Oct 17, 2007 8:34 pm Reply with quote
Product Description & Review:
With their compact design, SONEVA downflow fan heaters are the popular choice for heating bathrooms and ensuites as well as kitchens. The powerful 2kW output ensures a fast warm-up, although 1kW output is selectable on installation for smaller rooms.
This heater must be hardwired by a qualified electrician.
Taken from the Ebay site
and from the Soneva site
http://www.soneva-shop.com/products/bathroom-fan-heaters.html
This product must be hardwired by a qualified electrician in accordance with current UK Electrical safety regulations
So a plug and socket are NOT possible.
And frankly the idea of an un-earthed 2Kw fan heater in a bathroom wpuld make me very worried.
Back to top
 Alert Moderators
Space cat
from United Kingdom
Thanked: 74 times
PostPosted: Wed Oct 17, 2007 9:22 pm Reply with quote
Does this heater have the double insulated (class II) symbol on it? That's two squares, one inside the other. If it does then that's no bad thing in a bathroom. It won't need an earth; there will be nowhere to connect one! icon_smile.gif
That's the good news. The bad news is that what bernardgreen has found is correct. Note the word "hardwired". That's an FCU, not a plug and socket. It also says 2kW. There is virtually no chance that the old fan cable will be up to the job. icon_cry.gif icon_cry.gif icon_cry.gif
Back to top
 Alert Moderators
emphasis303
from United Kingdom
PostPosted: Wed Oct 17, 2007 10:50 pm Reply with quote
thanks for all your comments, im guessing it is the double square thing will double check in a bit,
if it is then the only problem is how to hardwire this. i need to connect it to an fcu but where could i do this.
im a bit new to all of this stuff so u can laugh if im complelty off it but i have a main electric box in the garage which is where i turn off and on the elctrics for the house, do i need to connect it to there? or should there be like a sort of junction box in the house? if so where would i find this? and am i just connecting a normal 3core cable from it to the bathroom.
Also just read somewhere ( from this link http://www.diynot.com/forums/viewtopic.php?t=94431)
that you can connect it to the internal wiring of a double socket? I have one of these in a room nearby so would this be possible? if so how?
Thanks once again for all your help
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Wed Oct 17, 2007 11:02 pm Reply with quote
ok.. STOP RIGHT NOW...!!!
the work you are describing is notifiable under part P of the building regulations meaning that you will either have to tell the local building controll authority and pay them to come and check your work, or get a registered electrician in to do the work for you..
this would seem to be the better option for you as from the sounds of it you are not competent to do this work, nor are you informed enough to do it safely..
for example you can only place these things in certain zones in the bathroom and they need connecting to the bonding in the bathroom..
Back to top
 Alert Moderators
Space cat
from United Kingdom
Thanked: 74 times
PostPosted: Thu Oct 18, 2007 10:12 am Reply with quote
I agree with ColJack. If this is your first venture into DIY electrics a bathroom heater is not the safest place to start. icon_eek.gif icon_eek.gif icon_eek.gif Try a simple light instead. icon_smile.gif icon_smile.gif icon_smile.gif
Back to top
 Alert Moderators
bleach
from United Kingdom
PostPosted: Thu Nov 08, 2007 10:20 pm Reply with quote
how did you get on with the installation? \i have the same heater, and it comes without a flex! I was looking for 1mm heat resistant 2 core flex but can only find 3 core. - Will this be ok to use if I just ignore the earth wire????
Back to top
 Alert Moderators
emphasis303
from United Kingdom
PostPosted: Wed Jan 09, 2008 4:56 am Reply with quote
lol, if i told u i just connected it to a socket in another room and it wasnt earthed as its double insulated would you blive me? Also using twin and earth but just cut the earth back?
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Wiring a bathroom heater. 19 2960 Sun Jan 10, 2010 1:40 pm
Wiring of bathroom fan and heater 2 40 Mon Oct 03, 2011 12:22 pm
Advice req. on routing bathroom mirror heater wiring. 2 580 Sun Aug 03, 2008 9:27 am
Bathroom Panel Heater 10 200 Mon Jun 18, 2012 2:31 pm
Installing wall fan heater in bathroom - advice, please ? 8 140 Mon Feb 11, 2013 6:29 pm
DIYnot
