DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Don't know house alarm code.....help !
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones
Author Message
wiffers2003
from United Kingdom
PostPosted: Sat Oct 20, 2007 1:50 pm Reply with quote
Hi all, I've recently moved house and found that i don't have the code for the house alarm and neither does the previous owner (he never used it!).
Is there any way that you know of where i can overide it and reset it somehow.
The alarm is a "C&K Securitech Active 5" unit.
Many thanks Carl
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 131 times
PostPosted: Sat Oct 20, 2007 2:28 pm Reply with quote
iirc it is usully possible to completely reset an alarm to factory settings, the trouble is you will need the engineers manual and some alarm experiance to reprogram it after doing so.
Back to top
 Alert Moderators
wiffers2003
from United Kingdom
PostPosted: Sat Oct 20, 2007 6:09 pm Reply with quote
Thanks for your reply plugwash. I do have the engineers manual and it does say about resetting it, the only thing is that it then says that i would have to call the manufacturer to complete the reset and i don't want to have to pay them to come along and push a button. Is this the normal way to do things and what would be a common charge (if any!) to complete the reset.
I am worried because at the moment the alarm sounds if the power is switched off and i wouldn't be able to disable it in the event of a power cut.
thanks.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Sat Oct 20, 2007 6:20 pm Reply with quote
that does not sound right, about calling the maker.
try lookinhg in the manual for defaulting or lost codes
or post what it exactly says
Back to top
 Alert Moderators
wiffers2003
from United Kingdom
PostPosted: Sat Oct 20, 2007 6:52 pm Reply with quote
Ah Ha, Just found another bit in the manual about placing a small jumper link onto another position on the main pcb and removing the batteries and the power. This seems more reasonable and no need to contact the manufacturer.
Only one problem though, will the alarm sound if i remove the cover because of "tamper" operation?
I had better wait until the wife has gone out to do it (and the neighbours) just in case !!!!
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 131 times
PostPosted: Sat Oct 20, 2007 8:04 pm Reply with quote
yes unfortunately there is a good chance of setting off the alarm by opening the cover.
also if you remove both battery and mains you will most likely make the external sounder go off on it's own battery.
Back to top
 Alert Moderators
wiffers2003
from United Kingdom
PostPosted: Sat Oct 20, 2007 8:50 pm Reply with quote
Hmmm, maybe i'll warn the neighbour first then.
Thanks.
Back to top
 Alert Moderators
Space cat
from United Kingdom
Thanked: 74 times
PostPosted: Sat Oct 20, 2007 8:56 pm Reply with quote
It shouldn't do this. Your backup battery is flat. icon_sad.gif icon_sad.gif icon_sad.gif
That jumper will be to clear the memory.
Most alarms have a tamper switch on the box that sets an alarm off when you open it. If the alarm isn't armed at the time this will probably be no more than a small internal beeper. It sounds like you've got a self activating bell. This is what goes off when you switch the power off. As soon as you get the code back to its default setting (1234?) you can restore power and reset the alarm. This will silence the SAB.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 317 times
PostPosted: Mon Oct 22, 2007 4:27 pm Reply with quote
Intergalactic Feline, am I missing something big here??
How do you know he has a SAB or that the BUB is flat??
Back to top
 Alert Moderators
Space cat
from United Kingdom
Thanked: 74 times
PostPosted: Thu Oct 25, 2007 5:24 pm Reply with quote
The honest answer is that I don't. I was in a hurry so I made an intelligent guess, which might turn out to be wrong. I made the reasonable assumption that an alarm with a backup battery shouldn't go off during a power cut. It should continue to work as if nothing was wrong for as long as the battery holds up.
Since this alarm does go off when mains power is removed it follows that the backup battery is flat (or missing). With no mains power and no backup battery either, the only thing left to make a noise would be an SAB.
Back to top
 Alert Moderators
wiffers2003
from United Kingdom
PostPosted: Sun Oct 28, 2007 7:30 pm Reply with quote
You're absolutely right Space Cat. I do have a SAB and my back-up battery only measured 6V when it should have been 12V.
I have now managed to reset to the factory default code and then change it to my own choice, i apologised to the neghbours afterwards as the SAB did indeed sound for a while when i had the main box open to reset the code.
Thanks for your help.
Carl
Back to top
 Alert Moderators
Space cat
from United Kingdom
Thanked: 74 times
PostPosted: Sun Oct 28, 2007 7:51 pm Reply with quote
You're welcome. Since you have a manual for your alarm, might I suggest that you 'pay it forward'. Check the sticky "Alarm manuals" thread and, if yours isn't there already, put yourself down as a useful source of information. icon_smile.gif icon_smile.gif icon_smile.gif
Back to top
 Alert Moderators
wiffers2003
from United Kingdom
PostPosted: Sun Oct 28, 2007 10:37 pm Reply with quote
Of course, all information is useful especially if its free !
Not sure how to do it yet, but i'll sort it out soon.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 317 times
PostPosted: Wed Oct 31, 2007 3:50 am Reply with quote
[Slinks off with tail between legs...]
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones All times are GMT
Page 1 of 1
Jump to:
Reset code for house alarm 3 120 Mon Apr 29, 2013 8:56 pm
New house, new alarm, no code, no manual and now going off!! 5 1280 Sun Feb 14, 2010 11:00 pm
Forgotten Alarm Code - House Alarm 4 220 Sat Aug 06, 2011 8:02 am
alarm code 12 160 Tue Aug 16, 2011 8:44 pm
landlord has lost the alarm code????? 5 160 Thu Sep 08, 2011 3:02 pm
DIYnot
