Joined: 23 Jun 2004 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Wed Jun 23, 2004 10:07 am Post Subject:
Cooker hood wiring
Hoping for some help!
I have had a cooker hood bulb blow, but when I tested it, the whole hood now has no power. I can't even trace where the power is coming from - there is no switch/fuse in the kitchen specifically for the hood and all other appliances are working fine. House fuse box is fine. House is Bovis, 4 years old. Does anyone know where the power could be coming from? Lighting circuit? Mains socket circuit?
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Wed Jun 23, 2004 11:53 am Post Subject:
firstly you did test power coming into the hood didn't you if you just tested whether the hood worked it could be a fuse in the hood itself
failing that sounds like a fused connection unit somewhere off either the lighting (naugty but possible) or socket cuircuits
sadly finding it is likely to be a nightmare especially if its burried in a void somewhere
the thing is because the live is now disconnected (presumablly by a hidden fuse) you can't even find out what cuircuit it is on in the normal way
here is the troubleshooting approach i would take
turn off the main switch and rcd and open the CU
connect temporary wires (preferablly some bright color you would not normally see in a CU so it can be easilly removed lated) between the earth bar and the neutral bars
check for continuity with a multimeter between the earth and neutral wires at the cooker hood feed position
if there is no continuity at this stage you have seroius problems and should get a sparky in
then disconenct the neutrals of each cuircuit from the CU neutral bar one at a time and retest continuity at the hood (start with the likely ones like kitchen sockets and downstairs lights and cooker cuircuit if present)
when you find out which cuirciut it is put its neutral back in the bar and start breaking that cuircuit in various places until you find where its spurred from
Joined: 27 Aug 2003 Posts: 21990 Location: London, United Kingdom Thanked: 78 times
Posted: Wed Jun 23, 2004 6:13 pm Post Subject:
Re: Cooker hood wiring
Still under NHBC guarantee then. If the wiring wasn't done according to the regs (and an FCU hidden in a void is not according to the regs) then phone up and give them merry hell.
__________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Joined: 18 Jul 2004 Posts: 5166 Location: Devon, United Kingdom Thanked: 20 times
Posted: Sun Jul 25, 2004 9:09 am Post Subject:
Doh! Loads of people put the plug & socket behind the stainless 'chimney', its them clients that dont wanna see all those ugly sw fuses on the wall....and i must admit.....i agree.
Posted: Mon Jul 26, 2004 8:50 am Post Subject:
When you think how much money people spend on kitchens, how much extra would it cost to put in an appropriately styled grid plate with labelled switches and fuse modules somewhere accessible but not obtrusive and run a series of radials for all the non-cooking appliances from there? A lot less than just the tiling would be my guess....
Joined: 29 Sep 2003 Posts: 2205 Location: West Midlands, United Kingdom Thanked: 0 times
Posted: Mon Jul 26, 2004 11:11 am Post Subject:
Indeed, but you're forgetting the unbreakable rule of kitchen renovation - you don't even consider the electrics until everything else has been done... especially the tiling!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
