DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
oven bulb blowing
This topic originated from the How to page called Changing a fuse on the consumer unit
Click here to return to the page called Changing a fuse on the consumer unit.
  View previous topic :: View next topic
Author Message
bwfc3101
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 23, 2004 9:02 pm    Post Subject:
oven bulb blowing
Reply with quote Thanks
i have recently installed a double oven on a 30 amp circuit only to find one of the oven lamps keeps blowing am i right in assuming my kettle or extractor is 'tripping out' my bulb when the switches are activated?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
BR
from Ireland
Thanked: 0 times
PostPosted: Wed Jun 23, 2004 9:16 pm    Post Subject:
No, you would not be right in thinking this. There are many reasons why the bulb might blow, i cannot see how switching on a kettle or extractor would have any effect on the bulb. Why do you think so?
Possible problems:
Incorrect bulb - the bulb is not correctly rated for the high temperature conditions.
Poor connection between bulb-holder and bulb.
High Voltage (unlikely)
How ling does the bulb take to blow? Is it blowing at all, simply not working perhaps. More info required.
If this is a new oven / cooker perhaps it is covered under warranty, as the problem is most likely related to the oven itself and not your fixed wiring
Back to top
 Alert Moderators
bwfc3101
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jun 26, 2004 7:48 am    Post Subject:
hi thanks for replying
i am lead to believe the tripping theory from my local diy shop-no not one of the sheds, the bulb blows when it wants and not at any particular time and the oven(double two lamps only one goes)is second hand off ebay other than this it is perfect in every waythe bulb is rated at 300c/25 watt icon_sad.gif
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sat Jun 26, 2004 3:54 pm    Post Subject:
Whoever told you that needs to go back to the job where all he had to say was "would you like fries with that?".
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Bulb blowing in one socket only 2 260 Mon Jan 28, 2008 11:05 am
Installed new light and bulb keeps blowing (1 gang to 2 gang 12 780 Sat Jan 05, 2008 9:50 am
installed a dimmer switch, but bulb blowing . . 15 700 Mon Jul 02, 2007 9:15 am
Electrical oven fuse keeps blowing 8 1940 Sun May 09, 2004 8:15 am
How do you change the bulb? 5 480 Wed Feb 13, 2008 9:26 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
