DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
time clock on first floor
This topic originated from the How to page called Installing an electric cooker
Click here to return to the page called Installing an electric cooker.
  View previous topic :: View next topic
Author Message
boratonpurim
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 23, 2007 9:28 pm    Post Subject:
Reply with quote Thanks
I would like to have a time clock on the first floor for the lights however both floors are on one 16 amp circuit all though it’s on 2 different cables. So normally I would just split them into 2 circuts, but there is no room in the consumer unit for an additional circuit. Any advice how to do it?
Thanks in advance .. joe[/img]
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue Oct 23, 2007 9:33 pm    Post Subject:
why are the lights on a 16A fuse, and what good is a time switch?
not a lot of use if no lights on when you want to visit the loo
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
boratonpurim
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 23, 2007 10:16 pm    Post Subject:
i dont know. thats the way it is 2 lines into the 16amp, 1 for first and for second floor. i want the first floor on a timer for when i leave for vacation etc. thanks.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue Oct 23, 2007 10:21 pm    Post Subject:
i would be inclined to find out why they are on a 16a fuse first
is it a fuse or plug in mcb?
as for the time switch, its easy but even easier is to buy plug in timers for table lights. (plug into sockets)
these will be less hassle, can be set at differnt times* (gives a better impression than all on or all off at same time) and have one / two for down stairs.)
when you come back unplug timers and save for next year
* ever seen the film home alone?
remeber the two baddies sitting outside the house?
__________________
Forum = Opinions
Back to top
 Alert Moderators
boratonpurim
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 23, 2007 10:32 pm    Post Subject:
its a plug in mcb.
well i'd prefer to install a timer since im away 8 days every month so i can set it up for the whole floor whenever i'd like. what are my options?
thanks
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Tue Oct 23, 2007 11:00 pm    Post Subject:
I would run from the MCB to a pair of FCUs for upstairs and downstairs. Then run the upstairs on to the timer.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Wed Oct 24, 2007 5:00 am    Post Subject:
perhaps some one only had a 16a mcb?
__________________
Forum = Opinions
Back to top
 Alert Moderators
boratonpurim
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 24, 2007 11:40 am    Post Subject:
that's possible, bottom line is it ok like that or it has to be changed? Thanks
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Wed Oct 24, 2007 4:04 pm    Post Subject:
Why do you need to split the circuit? Just switch the UPSTAIRS leg from the mcb with a timeclock!
Three core + E from CU to time clock. Brown into MCB with downstairs cable, grey (sleeved blue) to the neutral bar, join the upstairs light cable to the black in the three core.....
So fuss - zero hassle - piece of p**s!
Just find out why it's a 16amp!
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Wed Oct 24, 2007 4:46 pm    Post Subject:
I would guess it is a 16A because one lighting circuit fused at normal lighting circuit levels wasn't enough for the lights that are fitted.
It is not advisable to have lighting circuits protected only by a 16A breaker (and it is a violation of the regs if there are any SES or SBC lampholders). That is why I suggested the use of FCUs.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
replacing biasi 24s time clock 2 200 Fri Feb 15, 2008 2:52 pm
Wiring a 48 Hour Time Clock 16 560 Thu Sep 28, 2006 11:13 am
Central Heating Clock/timer 9 460 Thu Nov 01, 2007 8:01 pm
Clock for Economy 7 meter 5 580 Sat Nov 05, 2005 12:58 pm
Re-wire - one floor at a time? 6 740 Thu Jan 15, 2004 11:45 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
