DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
External PIR Light Problem
This topic originated from the How to page called Adding a new light and switch
Click here to return to the page called Adding a new light and switch.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
Trem
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 25, 2007 5:58 pm    Post Subject:
Reply with quote Thanks
Hi guys, first post so go easy.
I have fitted an external halogen light with PIR , I have gone from the existing main wiring (not light wiring as it didn't have earth). I have used a 30A junction box and run from that (2.5mm twin core and earth) into a 3A FCU (none switched). All went well and there seemed to be no problems apart from......the light won't work. Have I made any glaring errors in what I have done? I have not checked the bulb as yet and I am hoping that is the problem but it is never that easy.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
luminaire
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 25, 2007 6:52 pm    Post Subject:
Check the bulb first and if still no joy get back to us.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Thu Oct 25, 2007 7:09 pm    Post Subject:
Thats a bright idea.
(breezer gets coat)
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Thu Oct 25, 2007 7:13 pm    Post Subject:
Sometimes halogen lamps can be put in apparently correct but the ends just are off contact from the live/neutral nibs at one or both ends.Just double check this to be sure.
__________________
Empty barrels make the most noise.
Back to top
 Alert Moderators
Trem
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 25, 2007 7:14 pm    Post Subject:
I was doing it at my mums and by the time the light wasn't working I just wanted to get out of there. She was watching me up the ladder screeching "BE CAREFUL LOVE!" and everytime I went inside to check the wiring the heating that she had set to 'Saudi Arabia' made me melt.
I will mess with the bulb tomorrow and let you know guys.
Cheers.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Thu Oct 25, 2007 7:16 pm    Post Subject:
its a lamp, not a bulb, and dont touch it with your fingers, use a small piece of paper folded in half, then poke it round the lamp then hold the paper
__________________
Forum = Opinions
Back to top
 Alert Moderators
Trem
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 25, 2007 7:18 pm    Post Subject:
Yeah, its a hard habit to get out of. My tutor often screamed "BULBS ARE PLANTED IN THE GARDEN!"
I know about the not touching the lamp, used kitchen roll to hold it when I inserted it.
Back to top
 Alert Moderators
Trem
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 26, 2007 2:31 pm    Post Subject:
Checked everything outside, light is fine and so is the lamp, well they don't work still when I swap them with a new light so I can't see me having 2 duff lights and bulbs.
The problem is at the fuse spur, I have power going in but it is blowing the fuse so obviously no power going out, I tested this with the light connected and disconnected and outside there is definitely no power.
Any ideas what could be causing the fuse to instantly blow? Is this a case of rewiring the whole thing in case there is a break? I have rewired the junction box onto another source and used 20A one this time but it is exactly as it was before.
Any help appreciated.
Back to top
 Alert Moderators
Steve3948
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 26, 2007 5:52 pm    Post Subject:
How have you connected your light ?????
Most PIR Lights have connections that you do not connect to, they are for internal links between PIR and Light.
Sounds like a Live to Neutral fault.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Oct 26, 2007 6:29 pm    Post Subject:
you dont mean the fuse in the FCU do you? what size is it?
__________________
Forum = Opinions
Back to top
 Alert Moderators
luminaire
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 26, 2007 7:05 pm    Post Subject:
How did you wire the FCU?
Back to top
 Alert Moderators
Trem
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 27, 2007 12:07 am    Post Subject:
The light only has L, N and E and it has no dials to set the walk distance or daytime/night time activation. Just a PiR with a light with only 3 internal connections.
I have gone from the source (socket ring) into a junction box, out of that into the FCU then out of the FCU through the wall outside then into the light. I have a 3A fuse in the FCU. I have checked everything twice and everything is wired as it should be, the only thing I haven't checked yet is the wire from the FCU that goes outside.
I do get power going into the FCU but none going out/getting past the fuse as it blows as soon as power is turned on.
There are no wires touching and everything is where it should be, apart from the one I haven't checked yet, but in my mind it seems to be a problem before the outside wire.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Sat Oct 27, 2007 12:22 am    Post Subject:
If you're not sure, post a picture of your wiring.
Back to top
 Alert Moderators
festa
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 27, 2007 5:25 am    Post Subject:
O.k first thing first...
What wattage is the lamp ?
Second...
Go buy yourself a multimeter and double check the length of cable for the section between FCU and luminair for continuity.
Third...
Try changing the FCU plate for a new one as sometimes cheap makes could be faulty and while your at it for future convienience pay a few extra pennies and buy a SWITCHED FCU as some security lights have a facilty to switch it on perminantly if you want to.
__________________
17th Edition..here we come!
You can teach people to re-wire a plug but cant teach them manners.!
Back to top
 Alert Moderators
DESL
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 27, 2007 7:05 am    Post Subject:
Has this cable been damaged?
Did you replace this cable?
Is it run in conduit or straight through the wall?
If not could this be the reason the old light failed.
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
External Security Light With PIR Sensor 9 620 Tue Mar 17, 2009 7:24 am
external ceiling light 3 1420 Wed Mar 07, 2007 9:54 am
Two way external infra-red light switch 6 1980 Sat Sep 24, 2005 3:54 pm
External Light 9 460 Sun Nov 28, 2004 2:00 pm
external intruder light 3 400 Sun Mar 05, 2006 7:31 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
