so wait..
theres power to the FCU, but the fuse blows every time you put the power on..
you havent checked the cable going from the FCU to the light...
do you not see the severe lack of logic to your fault finding..???
if the fuse blows start at the light , disconnect it and put the wires into terminal blocks..
if the fuse doesn't blow then it's the light..
if it still blows then disconnect the outgoing cable from the fcu and try again..
if it doesn't blow then it's the cable..
if it still blows it's the FCU itself that needs changing.
