DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
new lights and switch
This topic originated from the How to page called Extending a ring circuit using junction boxes
Click here to return to the page called Extending a ring circuit using junction boxes.
  View previous topic :: View next topic
Author Message
pekay
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 24, 2004 11:29 pm    Post Subject:
Reply with quote Thanks
hello all, advice needed, i,m i the middle of converting the loft into a bedroom, i have an existing light switch and double socket in the room below and an existing double socket already in the loft(spur)i want to change the switch in the room below into a two way and also want to install up to 4 wall lights in the loft, i have easy access to all the wiring in the loft (existing lighting ring and junction boxes)what,s the best way to go about it, go off an existing jb or break into the circuit and install a new jb. ta.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Jun 25, 2004 5:40 am    Post Subject:
look in the reference section for how its done
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Fri Jun 25, 2004 8:07 am    Post Subject:
Hope you've
a) applied for planning permission
b) put in a proper staircase with a fire door at the top
c) ditto a velux with means of emergency escape*
d) Installed mains linked smoke alarms on main & top landings
e) installed proper joists for the loft floor
etc........
* not sure if this is a national requirement or is unique to certain local authorities.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Timer switch with low-energy/fluorescent lights 7 320 Sun Jan 14, 2007 10:38 am
2-core wiring in switch to 3-core loft 2 fluorescent lights 3 200 Wed Apr 15, 2009 2:18 pm
One switch - two outside lights - cant work it out - help 8 440 Sun Jan 14, 2007 12:29 am
2 lights 1 switch 2 3480 Sat Jan 27, 2007 6:10 pm
Two Lights controlled from 2 gang 2 way switch 4 460 Fri Sep 23, 2005 10:25 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
