Joined: 19 Oct 2007 Posts: 13 Location: Sheffield, United Kingdom Thanked: 0 times
Posted: Fri Oct 26, 2007 4:50 pm Post Subject:
Hello MrBob,
Martyc is right that the hot water will rise up to the bedrooms but 4 or 5 rads including 2 downstairs the pump is doing is job or the bottom 2 rads would also be tepid rather than hot.
1)When you bled the rads is the water relitively clear or a dark murky colour?
2)Have you recently started using the heating again?
3)Do you have TRVs on the rads?
Joined: 26 Oct 2007 Posts: 2 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Mon Nov 05, 2007 11:20 am Post Subject:
Thanks for your comments so far......
Update.
The pump is working fine.
I have turned off all upstairs rads and turned off water heating and turned up temp, and turned off all but the furthest rad from boiler. This comes through hot.
I then do the same with all downstairt rads to see if I have an air blockage. I can make all rads downstairs hot.
I then turn on upstairs rads and this cools down the downstair rads, if I then turn on water heating element of system, downstairs goes cold.
I have checked for air in system and bled rads - none!
Water from rads is clear.
I have been told that my upstairs pip circuit is seperate from the downstairs pip circuit???? Can this be?
The system has worked OK in the house for the past 5 years.
We do not turn it off in summer, only right down.
I am willing to work through this fault by a process of elimination.
Joined: 12 May 2004 Posts: 7929 Location: United Kingdom Thanked: 59 times
Posted: Mon Nov 05, 2007 12:20 pm Post Subject:
On the heating flow pipe from the boiler there should be an antigravity valve usually within a couple of feet , it is brass about 4 inches long. It is not unusual for these to jam and not to open properly.
So it restricts the flow to rads will let some work but not all ,a sharp hit with a small hammer can free them but they only cost about a fiver so best change it
Joined: 06 Nov 2007 Posts: 3 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Tue Nov 06, 2007 4:24 pm Post Subject:
Upstairs or downstair rads on but not both
I suffered a similar problem and the solution was to "power flush" the radiators by using a temporary connection to the main cold water supply. This flushes out any sludge which may be blocking or slowing down your CH flow. But it can be a lengthy procedure.
First drain the radiators; fit a stop cap to the 22mm CH vent which is above the CH header tank-important or you will have loads of water gushing into the header tank!; fit a drain hose to your lowest radiator drain cock; make a temporary connection between the cold water supply and a nearby radiator e.g. by removing a top bleed valve and connecting pipework to a nearby cold water supply.
Then close all radiator valves except one and turn on the cold supply.......this way you can force water through the rads at a reasonably high pressure. Open one radiator valve at a time until all have been flushed. Remove all temporary pipework, stop cap, re-fit bleed valve and refill the system.......... Good Luck with that lot.....it took me half a day but the result was that all radiators came on together again and I knew there was no sludge anywhere.
Joined: 28 Jan 2005 Posts: 10099 Location: London, United Kingdom Thanked: 188 times
Posted: Thu Dec 11, 2008 4:09 pm Post Subject:
open vent means you won't go wrong very often by saying it could do with a clean.
when that is done, convert to fully pumped; it will make the heating a lot quicker, the hot water quicker and should even give you a modest saving on your gasbill.
if you really want to improve things, you should also change it to a sealed system.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
