DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
battene battens battens
This topic originated from the How to page called Wooden flooring
Click here to return to the page called Wooden flooring.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
atinman
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 26, 2007 10:08 am    Post Subject:
Reply with quote Thanks
Sorry for a noobie question but I have decided to install brushed and oiled oak over old concrete using battens. Can anyone please tell me what size, material battens to use and if wickes is a good place to get them.
Thanks a lot
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Fri Oct 26, 2007 11:19 am    Post Subject:
Battens at least 50mm high, nails at least 50mm long.
Battens not further apart than 35 - 40cm
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
Symptoms
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 27, 2007 1:19 am    Post Subject:
Tini - we always use treated battens in this situation. If it's a very big area and you are intending to fix the battens consider hiring a Hilti cartridge nailer, with appropriate fasteners. How will you fix the boards down - secret nailing I hope? Oiled oak - you've made a good choice!!!
Back to top
 Alert Moderators
atinman
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 27, 2007 8:40 am    Post Subject:
Thanks alot for your quick reply .. was thinking that means my floor will rise by 7cm !
Is there no other way!!??
Good tip about the cartridge nailer too, thanks as well, and yes, I was going to hire a portanailer, or buy one from sfx and flog it when i finished!.
By the way, as for treated battens.. what do I ask for... "treated battens?" Thanks, AW
Back to top
 Alert Moderators
Symptoms
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 27, 2007 5:11 pm    Post Subject:
Tini - ask for treated battens or tanalised battens, same thing.
You could use thinner battens as they are resting on & fixed to the concrete - we use tile battens (2 x 1) where the 1" is the height.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Sun Oct 28, 2007 11:16 am    Post Subject:
Symptons, question for you re 2.54cm high battens. When you nail your 50 - 55mm long nails in an angle when secretly nailing, doesn't the nail hit the concrete????
__________________
Back to top
 Alert Moderators
Symptoms
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 29, 2007 9:54 pm    Post Subject:
WYL - an excellent question! No they don't 'cos we use cleats of different lengths according to the job in hand. 38mm long, 45mm long, and of course the bread & butter 50mm long.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Tue Oct 30, 2007 10:45 am    Post Subject:
So what length do you use when secretly nailing 19mm thick?
__________________
Back to top
 Alert Moderators
Symptoms
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 30, 2007 10:31 pm    Post Subject:
Anyway, 19mm thick, say 6mm approx tongue, cleat entry point say 11-12mm up from base of board, nominal 1" thick batten which in reality is 22mm thick. Apply a bit of Pythagoras and you come out with a 45mm cleat which would not break through the batten, or we could sized-up by eye. In reality a thicker batten, and longer cleats is always the way to go but as Tini is short of depth 2x1 is a satisfactory option.
Interesting observation however, 50mm cleats tend to deflect/bend horizontally when hitting the concrete so would work, but they'd be a bu**er to get out.
Back to top
 Alert Moderators
mattysupra
from United Kingdom
Thanked: 5 times
PostPosted: Tue Oct 30, 2007 11:02 pm    Post Subject:
test of your knowledge maybe symptoms. As big al says ' we are all still learning' At least i think thats what he says or is that someone else on here? But woody does seem to be a bit of a guru on the old wood installs. icon_biggrin.gif
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Wed Oct 31, 2007 10:05 am    Post Subject:
Symptoms wrote:
Not at all Symptoms, just wanted to hear more about it - hear to learn too, as everyone else. icon_wink.gif
Besides that, we hardly install on battens on concrete, still think it's a waste of money, effort and height. But that's just me icon_wink.gif
__________________
Back to top
 Alert Moderators
mattysupra
from United Kingdom
Thanked: 5 times
PostPosted: Wed Oct 31, 2007 7:53 pm    Post Subject:
and me, plus a weak point if the batterns leave the floor.
Back to top
 Alert Moderators
Symptoms
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 01, 2007 1:33 am    Post Subject:
Matty - of course correctly fixed battens don't "leave the floor". I suppose as there are no regulations regarding this type of work, only 'good practice' and that based on experience can guide us. When ever we've been called to offer this solution, done properly it'll stand the test of time - we've been at this game now for 34 years. Anyway, the OP specified battens and all/most posts are in this connection.
Back to top
 Alert Moderators
atinman
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 06, 2007 4:35 pm    Post Subject:
Hello again.. woodulike.. can you tell me how YOU install wood flooring over concrete..? i thought battens were a must.. (there are some slightly uneven surfaces in the flat)
and Symptoms, to affix battens, if that is what i use, can you explain how to use that a Hilti cartridge nailer and show a link to appropriate nails?
again everyone!
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Tue Nov 06, 2007 4:46 pm    Post Subject:
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Cross-battens in the loft, extra strength or extra weight? 3 1260 Wed Feb 13, 2008 9:29 am
loft insulation & cross battens 6 1200 Wed Aug 29, 2007 1:19 pm
Loft: What size cross battens? 3 1560 Sat Aug 18, 2007 3:19 pm
wooden floor on battens on concrete? 7 3020 Mon Nov 14, 2005 11:57 am
Hardwood flooring: Spacings for battens 8 720 Thu Jan 20, 2005 2:02 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
