Goods
Joined: 26 Oct 2007 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Fri Oct 26, 2007 7:57 pm Post Subject: render and DPC |
Had a DPC put in internally to 1 m and was advised that external pebbledash render should be removed to the same level. But a builder says that I am wasting my money and it doesn't need doing. He says it will look ridiculous, that there may be damaged brickwork underneath and that the external walls aren't damp. The DPC firm said that any survey would advise that the external render is too low. Help please. |
AndersonC
Joined: 05 Apr 2006 Posts: 460 Location: Lancashire, United Kingdom Thanked: 0 times
noseall
Joined: 02 Feb 2006 Posts: 11053 Location: Staffordshire, United Kingdom Thanked: 71 times
Goods
Posted: Sat Oct 27, 2007 11:35 am Post Subject: |
Thanks - as I don't know what I'm talking about I didn't describe that well -DPC firm hacked off plaster to height of 1 metre then injected DPC.
Outside the pebbledash render stops at height of 2 bricks above the ground. Why I'm not sure what to do is that the DPC company don't seem to gain anything from their advice - they don't do the work.
Can you tell me what bellcast is? |
AndersonC
Posted: Sat Oct 27, 2007 12:56 pm Post Subject: |
Well I'm not a plasterer, renderer or builder, however I understand the bellcast to consist of a bead which forms the render out away from the wall, allow rainwater to drip clear of the wall. |
