DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Noisy toilet cistern when filling
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Paul_Thomas
from United Kingdom
Thanked: 1 time
PostPosted: Sat Oct 27, 2007 10:35 am Reply with quote
I have a standard coupled basin/cistern, approx 18 years old.
When you flush the toilet there is a fog horn type noise, I have taken the top of the cistern and the noise stops when i pull the ball up.
The cold water feed pipe vibrates quite badly when the noise happens and you put your hand on it.
What could be causing this and is there an easy fix?
Thanks in advance for your assistance.
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 80 times
PostPosted: Sat Oct 27, 2007 10:52 am Reply with quote
Change the washer in the float valve.
Back to top
 Alert Moderators
Paul_Thomas
from United Kingdom
Thanked: 1 time
PostPosted: Sat Oct 27, 2007 11:11 am Reply with quote
Hi Bahco
Can you point me in the direction of any pictures/diagrams showing what this part is?
Typically how easy is this to change on an old cistern?
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 80 times
PostPosted: Sat Oct 27, 2007 11:15 am Reply with quote
Is your float arm a plastic / metal one with a ball attached. icon_question.gif
Back to top
 Alert Moderators
Paul_Thomas
from United Kingdom
Thanked: 1 time
PostPosted: Sat Oct 27, 2007 11:18 am Reply with quote
Yes it is all plastic inside. Made by armitage shanks circa 1989.
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 80 times
PostPosted: Sat Oct 27, 2007 11:23 am Reply with quote
At the end of the arm you will see a large (1 1/2 inch) round nut which unscrews and gives you access to the washer.
Might only need cleaning out.
Back to top
The following user says thank you to Bahco for this useful post:
sjroberts1 (24 Sep 2012)
 Alert Moderators
Paul_Thomas
from United Kingdom
Thanked: 1 time
PostPosted: Sat Oct 27, 2007 2:00 pm Reply with quote
Thanks, I'll take a look.
Back to top
 Alert Moderators
Paul_Thomas
from United Kingdom
Thanked: 1 time
PostPosted: Sun Nov 18, 2007 8:50 am Reply with quote
UPDATE:
Problem sorted, I removed the rubber washer then cleaned it up with some hot soapy water. I sprayed it with a silicone rubber lubricant and refitted it.
Now nice and quiet.
Back to top
 Alert Moderators
TMH
from United Kingdom
PostPosted: Fri Dec 31, 2010 12:54 pm Reply with quote
Thanks to all for the tips on how to cure this problem.
10 minutes of stripping and cleaning the washer, replacing and testing and job done.
Saved me a 60 call out charge and probably the cost of a whole new inlet assembly as I'm sure most plumbers would have recommended replacing the whole part, rather than just cleaning out the dirt that was causing this problem !
I must confess to being rather worried it might be something more serious as we have very high water pressure in our area, thankfully it was no more than a dirty washer !
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1475 times
PostPosted: Fri Dec 31, 2010 1:02 pm Reply with quote
float valves only cost a few pounds, and it is quicker and easier to undo the big ring nut and take the working parts off the stem as a sub-assembly, and swap old for new. Later, you can strip, clean and re-washer your old one, and keep it handy for next time.
this is even more true for valves in the loft, where it is often dark, cramped and dirty. I leave a re-washered valve in a plastic bag next to the loft tank.
BTW rather than putting back the worn old washer, a bag of new ones is very cheap.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Noisy loft cistern re-filling 3 1780 Tue Jan 16, 2007 8:12 pm
noisy filling of cold water tank and cistern 2 100 Mon Jan 06, 2014 12:40 pm
Toilet cistern keeps filling 7 660 Tue Sep 23, 2008 8:56 am
Toilet cistern not filling and cold water tap not running. 7 1400 Thu Jan 07, 2010 12:47 pm
Toilet cistern filling injector nozzle sizes 4 60 Fri May 16, 2014 4:25 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
