Joined: 28 Oct 2007 Posts: 3 Location: United States of America Thanked: 0 times
Posted: Sun Oct 28, 2007 1:35 pm Post Subject:
squeaky floorboards
I live in a straight ranch with oak flooring in each room (except kitchen). All areas are carpeted. Squeaking occurs in a straight line starting in the kitchen into the dining room, down the hall and into a bedroom at the end of the hall. This is the heavy traffic area in my house. I cannot handle this job myself and am wondering if anyone can give me an idea of what a fair price would be to complete this repair. I will be putting the house up for sale next spring and want to address these types of problems beforehand. I imagine the squeaking would turn off a potential buyer. Many thanks for your advice.
Joined: 12 Jul 2004 Posts: 5771 Location: Surrey, United Kingdom Thanked: 24 times
Posted: Sun Oct 28, 2007 2:04 pm Post Subject:
heeeelllooo and welcome Helen Joan
assuming its flooring on joists
and assuming you can get talcum powder in america
rub it into the the gaps inbetween the boards and your squeeks are likly to greatly reduce or dissapear providing its board to board contact causing the problem
the long term solution is to tighten the screws or nails
if its hidden fixings then its a pro job to repair
__________________ big all
we are------------------ all still learning
Joined: 11 Sep 2007 Posts: 1297 Location: United Kingdom Thanked: 0 times
Posted: Tue Oct 30, 2007 1:10 am Post Subject:
Helen - which way do the boards run? At right-angles or parallel to the route you walk? Do you have a basement so you can see the underside of the floor and joists? Do the joists/beams span large distances unsupported? My guess is, because your squeak is happening in-line, the problem is being cause by a deflecting joist or beam.
Posted: Tue Oct 30, 2007 6:28 pm Post Subject:
squeaky floorboards
Good day!
To answer your questions, the floor boards are parallel to the route I walk and are nailed to joists that are 18 inches apart. If it makes a difference, there is a steel beam that runs down the center of the basement supported by two steel poles. The joists rest on this beam across the width of the basement. The boards look (to my untrained eye) pretty secure and tight.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
