Joined: 28 Oct 2007 Posts: 6 Location: London, United Kingdom Thanked: 0 times
Posted: Sun Oct 28, 2007 7:37 pm Post Subject:
Fuse keeps blowing
I have diming lights in all my rooms. A few weeks ago 2 lights blew within a week of each other in the bedroom. These have now been replaced, however the main lighting fuse in the fuse box keeps blowing. This specific fuse powers lighting in the bedroom, toliet and bathroom.
I thought that this could be happening due to the new bulbs but I have taken them out but it the fuse keeps blowing. Each time the fuse goes i leave it for a few minutes then I flick the switch back to normal. Is this the right thing to do?
Any ideas, help to why the main lighting fuse keeps blowing?
thanks
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Sun Oct 28, 2007 7:58 pm Post Subject:
This is happening as you have a fault. It is not a good idea to keep resetting the breaker with the fault still there. When does it trip, when the lights are on or with all of them off? Does it trip immediately or after a short time? It could quite easily be something heat related or something which has been disturbed, your best bet is to ask your friends if they know a reputable electrician which can come and take a look.
Posted: Sun Oct 28, 2007 9:22 pm Post Subject:
Hi there
The fault happens when the lights are on in at least 2 out of the 3 rooms. It doesn't happen straight away but after about 30-45 mins. We moved into the flat about 5 months and it was completely gutted before we moved in. It is really strange as we have had no problems before and it has only just started happening.
Posted: Sun Oct 28, 2007 9:46 pm Post Subject:
Saying that, the total load for 15x50w is just over 3 amps which shouldn't be a problem. Are they mains halogens? Is there plenty of space above for the fittings to disperse heat? I'm thinking it could easily be something overheating. Best get someone in tbh.
Posted: Sun Oct 28, 2007 9:52 pm Post Subject:
yes they are mains halogens. there seems to be enough space. If it is a problem of over heating would an electrician be able to sort it easily and cheapily?
Joined: 18 Mar 2005 Posts: 605 Location: United Kingdom Thanked: 0 times
Posted: Sun Oct 28, 2007 9:55 pm Post Subject:
right, easy to rule out breaker, that may be the problem.
change it to a new one about £3
or if you have two lighting circuits swap cable from one breaker to the other if problem moves to the other circuit you know its the breaker gone oversensitive.
if its not the breaker i would change the dimmer in the room where you had the light bulbs blow, change it to a simlpe light switch as they are cheaper if it turns out to be something else
hope this helps, this is what i would do
I think when the OP asks
Quote:
Sorry, where would I find the MCB - on the lights or on the fuse box?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
