Coachdiscus
Joined: 29 Oct 2007 Posts: 1 Location: Sussex, United Kingdom Thanked: 0 times
Posted: Mon Oct 29, 2007 5:57 pm Post Subject: Installing a light switch |
I'm converting a shed to an office and previously off one "cable" there were lights and sockets. We have had to remove some wires and are starting from a pretty basic point.
We have wired in a Plug Socket using the solitary cable coming into the building, can we run power from this socket to a light switch and then onto the light itself?
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Mon Oct 29, 2007 6:48 pm Post Subject: |
nope.
do a search for, power to shed, garage outbuilding etc, there is a lot more to it and has been done 722 times __________________ Do you like music Mr Finch?
Forum = Opinions |
Chri5
Joined: 19 Jan 2007 Posts: 1827 Location: London, United Kingdom Thanked: 28 times
Posted: Mon Oct 29, 2007 7:52 pm Post Subject: |
If you put a fused spur next to it and fuse it at 3a you can then run the load side of the fused spur to your light fitting- this uses the fused spurs switch as the lights on / off.
External electrics is more prone to issues and is Part P works. Hopefully your cable route to the main house is safe and suitable for use, with RCD fuse protection and cable correct for the weathering and wetting it may suffer. |
