jryoung
Joined: 30 Oct 2007 Posts: 1 Location: Surrey, United Kingdom Thanked: 0 times
Posted: Tue Oct 30, 2007 12:36 pm Post Subject: Bosch Dishwasher SVG43A03GB Bottom Rotor Arm |
Hi there, my Bosch Dishwasher SVG43A03GB (integrated unit) has a problem - the lower rotor arm doesn\\\'t rotate. The top one does, and so the pump seems to work just fine (unless there is a separate pump for the lower arm). The water gets hot, and the lower arm can spin freely by hand. Is it simply a blockage in the short bit of tube between the impeller and arm? What do you use to clear it? |
brayer
Joined: 06 Jan 2008 Posts: 3 Location: Devon, United Kingdom Thanked: 0 times
Posted: Sun Dec 28, 2008 11:02 pm Post Subject: lower rotor not working |
hi there
i am having an identical problem with my dishwasher which is the same model as yours, i've blowed through the hole the water comes up through to get to the rotor and it seems clear but no water comes up with dishwasher running and rotor removed.did you ever get to the bottom of the problem? |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Mon Dec 29, 2008 9:33 am Post Subject: |
Deleted __________________ Do you like music Mr Finch?
Forum = Opinions |
