DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Insulate between eaves too?
This topic originated from the How to page called Loft Insulation
Click here to return to the page called Loft Insulation.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
Maceoid
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 31, 2007 10:50 am    Post Subject:
Reply with quote Thanks
I've just finished insulating my cottage out in the wilds of Scotland. I laid 200mm space blanket on top of the (very) old and (very) thin insulation, then boarded on top. Pipes and water tank duly lagged too.
However, as it gets so cold in winter, is there anything else I can do?
Is putting more insulation (wool? space blanket?) between the eaves of the sloping roof an option?
My neighbour just boarded over his eaves with MDF 'to stop draghts creeping under the tiles'. Is this enough?
Believe me, it's FREEZING when the wind blows out here. Any help appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
freddymercurystwin
from United Kingdom
Thanked: 41 times
PostPosted: Wed Oct 31, 2007 9:23 pm    Post Subject:
I suppose it might help, although mdf isn't a very wise idea. Best to add more insulation at ceiling level, once heats escaped past that level whats the point in retaining it? Better to reduce the heat loss through the ceiling in the first place. You should also try and reduce the draughts round the rest of the property keeping proper ventilation in mind.
You could always get yourself one of these fellas; http://www.betterlifehealthcare.com/view_product.php?prodID=4214 icon_biggrin.gif
Back to top
 Alert Moderators
Maceoid
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 01, 2007 10:34 am    Post Subject:
Cheers Fred - that might be Plan B!
To give you some idea of what I found, most of the old 'insulation' consisted of old newspaper, with some carpet thrown on top.
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 24 times
PostPosted: Thu Nov 01, 2007 12:52 pm    Post Subject:
you must leave adequate ventilation so unless you have vents in the tiles or airflow from eaves to eaves you shouldnt block off the eaves
__________________
big all
we are------------------ all still learning
Back to top
 Alert Moderators
sprayseal
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 06, 2009 9:24 am    Post Subject:
considering your situation it might not be an ideal solution but you might want to consider using an alternative form of insulation. There are many on the market which might do a more effective job. I currently own an insulation company and we use ************************. Its one of the most effective forms. If this option is not open to you then you could look at the airflow around the home. See if there are any exposed gaps etc. Windows and door ways are particularly prone to drafts.
Back to top
 Alert Moderators
Moderator 3
Moderator Comment
Posted: Mon Jul 06, 2009 10:46 am    Comment:
Please note rule 3 (NO Free advertising.) - See here for the forum rules.
freddymercurystwin
from United Kingdom
Thanked: 41 times
PostPosted: Mon Jul 06, 2009 10:37 am    Post Subject:
sprayseal wrote:
considering your situation it might not be an ideal solution but you might want to consider using an alternative form of insulation. There are many on the market which might do a more effective job. I currently own an insulation company and we use ****************************. Its one of the most effective forms. If this option is not open to you then you could look at the airflow around the home. See if there are any exposed gaps etc. Windows and door ways are particularly prone to drafts.
Spray foam insulation is the work of the devil, should be banned!
Back to top
 Alert Moderators
MutantBunny
from United States of America
Thanked: 0 times
PostPosted: Fri Sep 04, 2009 3:50 pm    Post Subject:
Saying 'Spray foam insulation is the work of the devil, should be banned!' without givng any reason why isn't very helpful. Please: post a reason?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Passing extractor vent through 'cottage style' eaves 8 1380 Tue Apr 04, 2006 10:59 am
Roof Space, Eaves Insulation 10 5820 Sun Feb 06, 2005 2:59 pm
Insulation to eaves 6 1880 Mon Oct 04, 2004 12:04 pm
Insulating eaves cupboard doors on loft room 5 3720 Tue Dec 12, 2006 11:34 am
Insulation and the eaves... 4 1300 Tue Oct 30, 2007 7:32 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
