DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
cavity insulation
This topic originated from the How to page called Wall Insulation
Click here to return to the page called Wall Insulation.
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  View previous topic :: View next topic
Author Message
webs
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 31, 2007 11:19 pm    Post Subject:
cavity insulation
Reply with quote Thanks
my property is a gable end terrace its about 85 yrs old .i recieved a grant for cavity wall insulation and a surveyor came round drilled a few holes in the walls and said we would be fine having it introduced into the cavity.But i have air bricks at low level on the outside,And wondered if it would hinder the process.A colleage of mine said i shouldnt be having it done as the cavity is there to let the walls and floor breath.what should i do any advice would be great.cheers
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Oct 31, 2007 11:34 pm    Post Subject:
the air bricks must not be blocked as they are to ventilate the space under the floor. They probably already have sleeves so give a "tunnel" through the wall. If they don't the insulation installers should fit them. You might be able to tell by poking a bit of stiff wire through. If necessary you could fit a sleeve yourself.
Back to top
 Alert Moderators
martyn306
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 27, 2007 7:07 pm    Post Subject:
do you have concrete or wooden floors
Back to top
 Alert Moderators
Madmog
from United Kingdom
Thanked: 1 time
PostPosted: Tue Nov 04, 2008 10:57 am    Post Subject:
We have had totally the same debate. After a couple of years we came to the conclusion that our house should be able to breath as the draughts creep in everywhere. We took the plunge about a month ago and the barometer on a north outside wall is generally reading at a higher temperature than I would expect and I think the house is generally a bit warmer than it would be after the heating has been switched off. I must admit I wasn't worried about the air bricks - none of the infill leaked out in that area and even if there are a few spots the infill didn't get into, a 98% filled house was probably better than none.
We went with Domestic & General and they were very efficient and willing to answer my questions.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Cavity wall insulation 6 400 Fri Jan 02, 2009 4:50 pm
3in cavity insulation 3 160 Mon Jan 19, 2009 8:27 pm
Cavity wall insulation 2 680 Wed May 30, 2007 9:11 am
Quick regulation 'quiz' question on cavity wall insulation 7 1100 Wed May 30, 2007 8:58 am
Minimum thickness of cavity wall insulation? 3 2040 Mon Jul 16, 2007 1:11 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
