DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
bathroom tap leaking advice please...
This topic originated from the How to page called Repairing a leaking tap
Click here to return to the page called Repairing a leaking tap.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
8ch
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 04, 2007 5:22 pm    Post Subject:
Reply with quote Thanks
monoblock bathroom sink tap is leaking from where the two "tails" (is that what they are called?) go up into the bottom of the tap. There is also a rod for operating the waste mechanism going up through same area.Water is dripping from up in there and is running down pipes and rod....Is there any connection up there? If not could the pipes(tails) have developed a hole? or what else could be the point of leak? Any advice welcome icon_sad.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Sun Nov 04, 2007 5:30 pm    Post Subject:
The two pipes usually screw into the bottom of the monobloc, sealing being done by an O ring. Often the O ring isn't good enough and the pipes have to be screwed firmly in.
If someone has soldered to them pipes, it can be a right pain cos they won't turn. More often than not the tap has to come out for a spanner to be applied to a part you won't reach.
Back to top
 Alert Moderators
tryitandsee
from United Kingdom
Thanked: 4 times
PostPosted: Sun Nov 04, 2007 5:36 pm    Post Subject:
The two tails are normally screwed in, they have small rubber o rings washers. May just need nipping up or relacing.
Often though, it's just the water from the basin leaking through down between the mono block/basin seal. If so, a gentle turn of the elongated hexagonal nut underneath where the tails are.
Back to top
 Alert Moderators
8ch
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 04, 2007 5:59 pm    Post Subject:
The two pipes are fixed to the hot and cold feed pipes about five or six inches below the monoblock. To tighten them I presume I would have to undo those connections? How do I tighten a pipe without crushing it? (you may have guessed that I am not too good or confident with DIY tasks - often making things worse - hence the trepidation...!)
How do I get enough play or slack in the assemby to lift the tap up?
do I need to?
I am confident that it's not water getting between the top of the basin and through the tap hole.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Help & Advice for fitting new bathroom 5 380 Tue Apr 04, 2006 10:08 am
Major bathroom re-furb - materials advice sought 2 800 Sat Jun 28, 2008 10:22 am
Replacing bathroom sink tap some advice needed 2 160 Tue Feb 24, 2009 8:32 pm
Bathroom & ensuite refurb - types of shower advice pls! 6 440 Thu Jul 10, 2008 9:00 pm
Pipe layout in bathroom - advice please! 8 300 Sun Mar 15, 2009 2:05 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
