DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Help! Rendering sagging/falling off
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
Author Message
dmcm
from United Kingdom
PostPosted: Sun Nov 04, 2007 11:33 pm Reply with quote
Hi there,
Any advice on this would be very welcome,
I am rendering a brick garden wall. I have coated the wall with a watered down mixture of cement sand and PVA additive, that has created a nice rough surface for the render to bond to.
I am using a mix of 1:1/2:4, cement/lime/sharp sand. I am applying the render with a metal plastering trowel. The render goes on fine, but after a bit it seems to sag in areas like its pulling away from the wall, one of the sections just peeled off. I have tried dryer and wetter mixes, but have the same problem. I noticed as I was smoothing out the render the trowel was bringing the water to the surface, thought that might be the problem so tried using a wooden float, but again the render started to bulge and fall off. I am applying the render approx 1cm thick.
Back to top
 Alert Moderators
marshman
from United Kingdom
Thanked: 30 times
PostPosted: Mon Nov 05, 2007 6:25 am Reply with quote
are you using a plasterzier or waterproofer in your mix
Back to top
 Alert Moderators
dmcm
from United Kingdom
PostPosted: Mon Nov 05, 2007 8:16 am Reply with quote
No plasterizer or waterproofer, just some lime.
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 529 times
PostPosted: Mon Nov 05, 2007 9:46 am Reply with quote
There is no question about it, the mix you have put on your wall is dead, and that is the cause of it slumping (sagging).There is no AIR in it.Making it wetter or dryer will not solve your problem.You will have to use a plasticiser at the very least in your mix, which will make it more"buttery", and preferably use a cement mixer.If you are mixing by hand,then you will have to work it very hard with the shovel.With a plasticiser in your mix,you will not need anywhere near as much water.You can always add water, but you can't take it out...A steel trowel will always bring water to the surface...Mixing mortar correctly is a skill in itself,and is always the key to a successful job.
Roughcaster.
Back to top
 Alert Moderators
dmcm
from United Kingdom
PostPosted: Mon Nov 05, 2007 10:45 am Reply with quote
Thanks for that roughcaster!!
I'm curious; what did people do before plasticiser?
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 529 times
PostPosted: Mon Nov 05, 2007 10:46 am Reply with quote
dmcm,
Another point I forgot to mention.It is always better to apply new cement render onto a proper scratch-coat.I wouldn't do it any other way.
Roughcaster.
Back to top
 Alert Moderators
diyisfree
from United Kingdom
Thanked: 1 time
PostPosted: Mon Nov 05, 2007 2:20 pm Reply with quote
Apply your render in two coats.
As roughcaster says, first a scratch coat, let that go off overnight, then following day second coat (final floating coat) DONT try to put it on too thick (max 8 to 10mm)
Leave it to stiffen then rub up with either a poly float or your wooden one. The more you keep messing with it, the more likely it will drop off the wall.
dont forget to make the second coat a weaker mix.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1234 times
PostPosted: Mon Nov 05, 2007 4:34 pm Reply with quote
also, wetting the wall helps.
Back to top
 Alert Moderators
dmcm
from United Kingdom
PostPosted: Mon Nov 05, 2007 4:37 pm Reply with quote
Thanks alot for all the advice everyone!
I tried again today with some plasticiser and the result was much improved; the render is still on the wall!!
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 529 times
PostPosted: Mon Nov 05, 2007 11:21 pm Reply with quote
Thanks for your feedback dmcm.
Roughcaster.
Back to top
 Alert Moderators
Micilin
from United Kingdom
Thanked: 301 times
PostPosted: Mon Nov 05, 2007 11:24 pm Reply with quote
Back to top
 Alert Moderators
csrt
from United Kingdom
PostPosted: Tue May 27, 2008 5:12 pm Reply with quote
yes you can use fairy liquid, but lime was used before the fairy liquid in the olden days, another tip for who ever wants to listen, add a small amount to plaster, bonding or browning that has gone off,and it will give you more time to use it, only for small jobs/areas or bedding beads, etc (not with multi finish) with this you,ll have to buy a new bag. cheers
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
Sagging ceiling-what to do? 7 800 Mon Mar 31, 2008 8:50 pm
boards sagging 25 380 Fri Jan 11, 2013 7:15 pm
Skim plaster falling off wall due to heat. 4 1660 Fri Nov 13, 2009 5:50 pm
Repairing/supprting victorian cornice to prevent it falling 4 440 Tue Nov 24, 2009 8:46 pm
Skim coat falling off plaster!!!!! 14 1100 Sun Mar 27, 2011 8:21 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
