DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Air in Power Shower?
This topic originated from the How to page called Installing a shower
Click here to return to the page called Installing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
pdrnsf
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 05, 2007 1:32 pm    Post Subject:
Reply with quote Thanks
I installed a power shower about 3 months ago and everything has been working fine.
The other day when running it the initial pressure seemed a bit low and the pump seemed to be making more noise than usual. To me it sounded like the pump didnt have enough water in it and was spinning faster.
Turning the shower on and off a few times resulted in the pressure returning and what sounds like a hiss of air coming out the shower head.
This is now happening every day. I installed a warix flange which I thought was supposed to stop air getting into it?
Anyone have any suggestions what could be causing this?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Nov 05, 2007 1:38 pm    Post Subject:
Is this a twin impeller pump?
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Mon Nov 05, 2007 1:39 pm    Post Subject:
If the water temp is cylinder is above 60c you can get caviatation (air bubbles) in the shower pump
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Nov 05, 2007 1:41 pm    Post Subject:
Cavitation doesn't result from air bubbles.
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Mon Nov 05, 2007 1:57 pm    Post Subject:
Was describing it in a way the guy could understand instead of in depth physics of why cavities also known as bubbles form which could be his problem , not saying it is the problem just a suggestion
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Nov 05, 2007 2:03 pm    Post Subject:
Air bubbles are one thing, and you're right this could be a cause.
Cavitation, which you mentioned, not me, is not the same thing as air bubbles, or indeed bubbles of anything.
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Mon Nov 05, 2007 2:17 pm    Post Subject:
As i said not going into physics of the cavities also describes as bubbles being partial vacums so in effect are bubbles of nothing
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Nov 05, 2007 2:19 pm    Post Subject:
Thank goodness you cleared that one up.
Back to top
 Alert Moderators
pdrnsf
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 05, 2007 2:36 pm    Post Subject:
Thanks for all the quick replies.
Yeah I believe it is a twin impeller pump, its a Watermill wasp 1.4bar pump.
If it is this Cavitation or air bubbles in the pump is there anything that can be done about it?
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Nov 05, 2007 2:41 pm    Post Subject:
FFS, have you checked the cold supply as well as the hot?
Back to top
 Alert Moderators
pdrnsf
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 05, 2007 2:52 pm    Post Subject:
It does get warmer all of a sudden too when it sorts itself out, could this imply that its the hot thats the problem?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Mon Nov 05, 2007 5:34 pm    Post Subject:
Check the water levels in the cold storage tanks in the loft
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Yet another power-shower question 14 620 Tue Jul 17, 2007 10:59 pm
weak power shower 22 3260 Tue Jul 10, 2007 11:18 am
Power shower with combi boiler? 10 1200 Wed Jul 18, 2007 9:56 pm
Power Shower with speedfit 4 260 Fri Jul 20, 2007 7:50 pm
Power shower(mira event) 4 480 Thu Aug 23, 2007 9:06 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
