DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
bleed valve
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
pods
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 08, 2007 5:36 pm    Post Subject:
bleed valve
Reply with quote Thanks
in our loft we have two small modern radiators.
With the weather today being cold I went to check them for air etc.
Instead of the bare valve there are plastic thumb valves with a hole in them to let air/water out.
However, despite turning them quite a bit I\\\'m getting no air or water coming out.
There is what looks like a slotted brass rod in the middle of the plastic valve which could have been moved by engineer during the annual boiler inspection, but I used to use just the plastic valves before.
Now I'm not sure if I've left them open or closed, but there is definately nothing coming out. icon_question.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Thu Nov 08, 2007 5:43 pm    Post Subject:
Try a screwdriver n the slot in the brass rod...
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Thu Nov 08, 2007 5:46 pm    Post Subject:
The slotted 'rod' sounds like the air bleed nipple its self. Does a radiator key fit over this? If not try turning in with a flat screwdriver to bleed the rads.
If no air or water comes out check (if you have one) that there is water in the expansion tank, or check the pressure gauge on your boiler or system is reading just over 1 Bar.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
pods
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 08, 2007 6:57 pm    Post Subject:
Whats the the thing with the hole then ?
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Thu Nov 08, 2007 7:05 pm    Post Subject:
Just something to guide the water jet.
COuld have been tight on the screw when it was new.
Back to top
 Alert Moderators
pods
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 08, 2007 8:12 pm    Post Subject:
thanks again
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Radiator Bleed Valve 9 640 Thu Apr 06, 2006 3:14 pm
Do all indirect cyliders need a bleed valve? 3 420 Fri Feb 24, 2006 6:02 pm
Automtic Bleed Valve 9 3700 Mon Oct 23, 2006 7:34 pm
fitting auto-bleed valve to radiator 4 2480 Sat Oct 28, 2006 6:13 pm
undo a cast iron rad leaking bleed valve that will not budge 4 1340 Wed Sep 12, 2007 7:07 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
