Joined: 09 Nov 2007 Posts: 5 Location: United States of America Thanked: 0 times
Posted: Fri Nov 09, 2007 9:28 pm Post Subject:
Radiator Valve
I am new to all this and just bought an apartment building with radiators; however, they are the type that do not have the spot for a key to bleed. So 2 questions 1)Does the valve on the left need to be screwed down shut or open for heat and 2)At the right end the valve is the type with numbers is this where I bleed the radiator? Please HELP
Posted: Fri Nov 09, 2007 10:49 pm Post Subject:
Left valve
Do you know whether the left valve has to be screwed open or screwed closed (all the way down) and I have looked at some different styles of rads online to find a similar one and many do not seem to have a way to bleed them up top, but I will take your word for it. One other thing do you know what the numbers that can be adjusted on the right valve do?
Joined: 23 Feb 2007 Posts: 14313 Location: Norwich, United Kingdom Thanked: 41 times
Posted: Fri Nov 09, 2007 10:52 pm Post Subject:
The higher the number the warmer the room will get.
The 'left' hand side is the locksheild balancing valve. The rads nearest the pump will need this closing down further than the rads furthest away so all the rads heat uo about the same.
Posted: Fri Nov 09, 2007 11:01 pm Post Subject:
Bleeding
You are awesome! So to make sure I understand even the olderst of rad models will have a air bleed valve and the has never been a model without one, right?
Joined: 10 Mar 2005 Posts: 3053 Location: Pakistan Thanked: 3 times
Posted: Sat Nov 10, 2007 2:52 am Post Subject:
There's a bit of general information here
Steam is naughty stuff to play with so I suggest you only only touch any obviously dedicated user controls until you have had some on site advice from an experienced professional.
__________________ Eagles may soar high but Slugs" don't get sucked into jet engines
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
