DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Copper Pipe to Plastic Pipe
This topic originated from the How to page called Repairing a burst pipe
Click here to return to the page called Repairing a burst pipe.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Canary
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 12, 2007 11:21 am    Post Subject:
Reply with quote Thanks
I am replacing a radiator following some building work and need to connect 12mm Plastic Pipe to my current 8mm Copper Microbore.
Is the most suitable method just fitting a compression reducer (12mm to 8mm) and are there any problems with connecting Plastic to Copper?? Or are there more suitable methods of connection etc?
Thank you in advance...
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Mon Nov 12, 2007 11:30 am    Post Subject:
As long as the joint is made properly then there are no problems.
8 mm heating is very much on the lower edge of being satisfactory from a flow rate aspect. That makes balancing quite important. Although the high resistance of the small tube has a self balancing effect if the lengths are similar.
Tony
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Underground Oil Pipe - Plastic or Plastic Coated Copper 5 1220 Thu Dec 27, 2007 11:33 pm
Plastic pipe v copper 14 940 Fri Sep 22, 2006 2:03 pm
Leaking connection between plastic thread and copper pipe 37 1140 Tue Mar 31, 2009 7:43 pm
Copper Compression Fittings with plastic pipe?? 11 1360 Mon Oct 31, 2005 2:29 pm
CH Btu carrying capacity of copper and plastic pipe 6 220 Thu Nov 20, 2008 8:44 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
