Pete and kell
Joined: 12 Nov 2007 Posts: 1 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Mon Nov 12, 2007 9:07 pm Post Subject: BOSCH classixx not working.! |
About 2 yrs old. In any program, seems to switch on check water light. Impeller pump starts to run and doesnt go off even when front door is open. Tried to reset float as there was a bit of water in base. This doesnt seem to be prob. Any clues anyone.
Thanks |
jgarrett
Joined: 08 Sep 2008 Posts: 2 Location: Down, United Kingdom Thanked: 0 times
Posted: Mon Sep 08, 2008 11:25 pm Post Subject: |
any luck with a quick fix for this.
I have the same problem. |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Tue Sep 09, 2008 6:03 pm Post Subject: |
Welcome to the Forums, i suggest you read the date it was asked, then check the post count.
1) Nov 12, 2007 22:07
2) 1
Since it was asked last year, and he only ever made the 1 post, i think its unlikely you will get a reply __________________ Do you like music Mr Finch?
Forum = Opinions |
jgarrett
Posted: Tue Sep 09, 2008 9:50 pm Post Subject: |
yes - seen that thanks but you don't loose anything by asking.
Maybe someone else could have the answer! |
gromitsmate
Joined: 22 Jul 2008 Posts: 67 Location: United Kingdom Thanked: 0 times
Posted: Fri Sep 12, 2008 8:44 pm Post Subject: |
what is the enr number found on the door |
foxhole
Joined: 14 Mar 2006 Posts: 735 Location: United Kingdom Thanked: 14 times
Posted: Wed Sep 17, 2008 1:40 pm Post Subject: |
Sounds like a blocked pump, jsut had one of ours fixed with same syptoms. |
JackieO
Joined: 25 Sep 2008 Posts: 1 Location: London, United Kingdom Thanked: 0 times
Posted: Thu Sep 25, 2008 7:41 am Post Subject: |
I've had the same problem and found my outlet hose had slipped and was not fixed at the recommended height of 20 - 30 inches above the ground. Could this be your problem? |
