DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
System info /Query
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
baluachrach
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 12, 2007 11:10 pm    Post Subject:
System info /Query
Reply with quote Thanks
hi just bought a new house with oil CH. The radiators in one half of the house come on when the CH is selected and the other half only come on when the HW is selected is this a normal system?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
chrishutt
from St. Pierre and Miquelon
Thanked: 2 times
PostPosted: Mon Nov 12, 2007 11:17 pm    Post Subject:
Sounds like you have two heating zones, but what about the hot water? Is that controlled separately or is linked into one of the heating zones?
__________________
Let's face FAQs.
Back to top
 Alert Moderators
baluachrach
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 12, 2007 11:23 pm    Post Subject:
hi thanks. have a Siemens RWB9 programmer when the CH is selected it heats half the house and when the HW is selected it heats the other half and also the hot water. problem is if i leave the hot water cylinder thermostat attached only the water heats but if you remove it from the clinder then the water and the radiators get hot. I presume this isnt right?
Back to top
 Alert Moderators
chrishutt
Thanked: 2 times
PostPosted: Tue Nov 13, 2007 7:57 am    Post Subject:
That doesn't sound right, but I think there may be more to this than meets the eye. Although the programmer has 2 timed zones, there may actually be 3 zones - 2 heating zones and the hot water zone. Can you find and describe the motorised valves which will probably be on the flow pipe after the pump. You might have a single 3 port valve or two or three 2 port valves. I'm assuming that it is a fully pumped system, but the hot water loop might be gravity.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
baluachrach
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 17, 2007 3:24 pm    Post Subject:
Thanks, sorry for the delay in answering.
I have checked and the only thing i can find is a grey box marked Drayton Mid position actuator part number is MA1. Does this help?
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Sat Nov 17, 2007 3:28 pm    Post Subject:
WOuldn't be the first time someone finds another valve hidden away which just does HW.
Can you follow thw pipes from the valve, eg to the cylinder?
How is the "heating" split - up and down might be by design.
Back to top
 Alert Moderators
baluachrach
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 20, 2007 12:00 am    Post Subject:
Can follow the pipes most of the way but there doesnt seem to be any other valves. sorry how do you mean " how is the heating split"? thanks
Back to top
 Alert Moderators
baluachrach
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 23, 2007 10:54 am    Post Subject:
can anyone offer anything else??
thanks
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Fri Nov 23, 2007 11:11 am    Post Subject:
maybe a long shot, but it might be a very old Drayton Flowshare valve .....point being they don`t Spring return like modern ones ........and if it`s old there may be a internal wiring problem ........best to give Drayton an email?.........Just an idea, might be completely wrong icon_wink.gif Not in East Sussex icon_question.gif I fitted a few way back in the mists of time .
Back to top
 Alert Moderators
D_Hailsham
from United Kingdom
Thanked: 71 times
PostPosted: Fri Nov 23, 2007 12:46 pm    Post Subject:
I think you will find that the MA1 is the current actuator.
However, I don't think this explains the OP's problem which is strange to say the least.
What is needed is either a photo showing the cylinder, valve pump etc or a sketch (using MS Paint and save as a jpg) showing how it is all plumbed together.
Which are the two halves of the house which get heated separately?Upstairs/Downstairs or what?
The RWB9 can be used with either fully pumped or with gravity HW pumped CH. This is set by the dipswitches on the back. Switch 5 is UP for fully pumped and DOWN for gravity+pumped. Check which it is, but don't change.
My thought is that some of the radiators may be on a gravity fed circuit together with the HW cylinder.
Is the house new construction or just new to you?
Are there any signs that the CH system has been altered? e.g different rads in one part compared to the other etc.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Central heating system diagrams - Info 2 5380 Tue Jan 29, 2008 2:58 pm
Syphonic WC suite - info needed 6 2800 Sat Feb 10, 2007 7:26 pm
worcester 28CDi diverter valve info needed 10 1520 Sun Dec 17, 2006 1:07 pm
Found some useful info on HepVo traps 5 3660 Tue Aug 01, 2006 10:15 pm
Immersion heater wiring info Req URGENT REQUEST GUYS 8 1420 Fri Mar 02, 2007 12:44 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
