DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
soil pipe connection
This topic originated from the How to page called Drainage Systems
Click here to return to the page called Drainage Systems.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
MarshallW
from China
Thanked: 0 times
PostPosted: Tue Nov 13, 2007 9:43 am    Post Subject:
Reply with quote Thanks
How do I fit a new soil connection to an internal, vertical and rigidly fixed existing soil pipe?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Sylvan Tieger
from United States of America
Thanked: 0 times
PostPosted: Tue Jul 15, 2008 9:04 pm    Post Subject:
Tieger plumbing
That sir would depend on local codes.
Some areas require bell and spigot where you have to use a hub joint with lead and oakum, other will allow the use of a mission coupling that will adapt from extra heavy cast iron to no hub CI
The key is to make sure the pipe is properly supported prior to cuttng
__________________
Guns kill, the exact same way a fork makes people fat and a car makes people drunk drivers
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue Jul 15, 2008 11:11 pm    Post Subject:
Sylvan Tieger, sorry mate, but i dont think the op cares anymore, he only posted that in 2007
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Wed Jul 16, 2008 12:10 am    Post Subject:
Re: Tieger plumbing
Why are you such a complete berk?
Back to top
 Alert Moderators
Sylvan Tieger
Thanked: 0 times
PostPosted: Wed Jul 16, 2008 1:32 am    Post Subject:
Thank you Breezer better late then never.
Thank you for letting me the problem was taken care of properly
__________________
Back to top
 Alert Moderators
Bambergaspipe
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 16, 2008 1:40 am    Post Subject:
Re: soil pipe connection
Coupling? if it`s cast you can fit a cast soil to plastic adaptor.then again you have probably diied by now. Bit like the Mods.
Back to top
 Alert Moderators
Sylvan Tieger
Thanked: 0 times
PostPosted: Wed Jul 16, 2008 1:51 am    Post Subject:
Yes as there are the following
1- Extra heavy cast iron pipe and fitting, Bell and spigot
2- Standard weight cast iron Bell and spigot
3- No Hub
where mechanical clamps are used
Transition couplings with a stainless steel band totally covers the rubber sleeve
http://www.missionrubber.com/Products/HeavyWeightCouplings.php
When working in a building over 130 years old it is not uncommon to find the origional XHCI in perfect condition so when connecting to an 8" diameter line it is cost effective to tie in a WYE fitting
There is also a stronger coupling torque to 120 in pounds but 80 will handle high head pressures in case of a stoppage
The outside diameter of plastic pipe would be the same as galvanized steel or NO HUB CI
Thank you for asking as some bloke said this post was long over and I guess people still tread here
Just takes one post to get some lively discussion thanks again for asking
Rspectifully, SylvanLMP/ LMFSPC /LMGF/LMD/LMSF
__________________
Back to top
 Alert Moderators
Sylvan Tieger
Thanked: 0 times
PostPosted: Wed Jul 16, 2008 1:58 am    Post Subject:
Hi Mate, I guess what you thought was wrong its ok even a broken clock is right twice a day.
By the way mate I would be "honoured" honored to have you as a friend as I do like your humour (humor)
__________________
Back to top
 Alert Moderators
Bambergaspipe
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 16, 2008 2:05 am    Post Subject:
Quote:
[quote="Sylvan Tieger";p="952516
I don`t think so, he`s already my friend & if you try to take him i will hurt you... icon_mad.gif
Back to top
 Alert Moderators
Sylvan Tieger
Thanked: 0 times
PostPosted: Wed Jul 16, 2008 4:01 pm    Post Subject:
__________________
Back to top
 Alert Moderators
wiggikins
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 16, 2008 4:14 pm    Post Subject:
__________________
Growing old is mandatory, Growing up is voluntary
Back to top
 Alert Moderators
Sylvan Tieger
Thanked: 0 times
PostPosted: Wed Jul 16, 2008 4:20 pm    Post Subject:
wiggikins wrote:
Can you please explain in English what "A DIVVY Ham Shank!!!" means Thank you
__________________
Back to top
 Alert Moderators
wiggikins
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 16, 2008 5:24 pm    Post Subject:
__________________
Back to top
 Alert Moderators
Bambergaspipe
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 16, 2008 5:56 pm    Post Subject:
wiggikins wrote:
Back to top
 Alert Moderators
wiggikins
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 16, 2008 6:13 pm    Post Subject:
MY OPINION IS MY OPINION , And i'd thank you to keep yer bugle out!!
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Soil Pipe & WC Connection planning problem 12 1320 Tue Mar 27, 2007 7:20 pm
plastic to cast soil pipe connection. 3 700 Sat Feb 17, 2007 6:12 pm
New waste connection to an existing soil pipe... 4 1880 Sun Apr 15, 2007 4:30 pm
shower waste pipe to soil stack connection 3 840 Mon Nov 19, 2007 8:23 pm
Copper soil pipe - how to make a connection 13 360 Tue Apr 28, 2009 12:46 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
