- Joined
- 13 Nov 2007
- Messages
- 1
- Reaction score
- 0
- Country
Hi folks, got problems with the above model not pumping out "uphill".
It drains fine when you unplumb it and run pipe out the door at ground level, it just doesn't pump out going into it's usual drain outlet. Everything is in accordance with installation instructions, it's worked fine for 5 years where it is?
Is the pump on its way out?
At present instead of pumping it just buzzes quietly and puts two error lights on to say its broken, useful as that is the tank full of dirty water kind of gives that fact away!
Thanks, Steve.
Thanks, Steve.
