Gas Boiler firing up intermittently
5 Jul 2004
Can someone help.
I have an old conventional gas boiler with a indirect hot water cylinder and 3 port motorised valve and pump. the boiler make is Stelrad Ltd, Wlx boiler. which will only light up for a few minutes then cut out, it does this intermittently. I have a Honeywell programmable timer and I have tried the hot water switched to always on but no action from the boiler. So I get no hot water or CH because the boiler wont fire up. There is a pilot light on the boiler and power to the timer. I have just had my hot water immersion cylinder replaced as well, could this be the cause?? or is it the timer or the gas boiler itself
im really stuck as to why the boiler wont fire up anymore
thanks for any advice
I can't tell because i can't hear anything coming from the pump but the pump is red hot, you can't touch it without burning yourself.
I have noticed that if I switch on the HW and CH to continously on, the pump makes a slow quiet hissing noise
The boiler make is by Stelrad Group and is a Ideal WLx gas boiler
sounds like your pump is either stuck or seized
If stuck try loosening the screw on the top and turning the shaft with a screwdriver
Failing that new pump
Pump depends on presence of water for lubrication, and water flow for cooling (although its pumping hot water!). If the casing is very hot, TURN IT OFF as a first step!! You may already have smoked the motor coil windings.
if i need a new pump how do i know what is the right one to get?
